Introduction
Please make sure your phone is turned off and the SIM card is removed prior to starting this guide.
Insert a SIM card ejection tool into the SIM card slot located on the left edge of the phone. Press in with the tool of your choice until it pops out of the side of the phone.
  • Insert a SIM card ejection tool into the SIM card slot located on the left edge of the phone.
  • Press in with the tool of your choice until it pops out of the side of the phone.
  • Remove the SIM card slot tray and set aside.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Starting at the SIM card slot, stick the plastic opening tool in between the back panel and the phone. Slide the opener tool gently around the phone until you hear clicks and visibly see the panel separate from the body of the phone.
  • Starting at the SIM card slot, stick the plastic opening tool in between the back panel and the phone.
  • Slide the opener tool gently around the phone until you hear clicks and visibly see the panel separate from the body of the phone.
  • Continue this process on each edge of the phone, until the only thing holding the back panel to the body of the phone is the fingerprint scanner.
A guitar pick is a good substitution for the plastic opening tool.
Sam Sippe - Reply
Here’s a photo of the location of the 18 tabs that hold the back cover in place
Steve - Reply
Gently detach the back panel from the finger print scanner on the back of the phone.
  • Gently detach the back panel from the finger print scanner on the back of the phone.
To reassemble your device, follow these instructions in reverse order. If your back panel is damaged or broken, then install the new panel instead.
22 other people completed this guide.
Isaiah Schultz
3,813 Reputation
19 Guides authored
Metro State, Team 1-1, Carpenter Spring 2016 Member of Metro State, Team 1-1, Carpenter Spring 2016
MSU-CARPENTER-S16S1G1
4 Members
19 Guides authored
One Comment
Bonjour,
Est-ce que vous arriveriez à m'indiquer l'espace disponible (en mm) entre le cache et la batterie svp?
Merci!
Lucas Marti - Reply
Past 24 Hours: 2
Past 7 Days: 30
Past 30 Days: 170
All Time: 6,455
