Network card Replacement
  1. Network card Replacement, Remove battery: step 1, image 1 of 1
    • Be sure to remove the battery to prevent any electrical shortage.
  2. Network card Replacement, Remove the backpanel: step 2, image 1 of 2 Network card Replacement, Remove the backpanel: step 2, image 2 of 2
    • Loosen all four screws and remove the back panel.
    • Remove the back panel with a spudger. Start out as in the second photo to prevent the plastic from breaking. Work you're way around the panel to remove it.
  3. Network card Replacement, Remove the antenna wires: step 3, image 1 of 2 Network card Replacement, Remove the antenna wires: step 3, image 2 of 2
    • In the red circle is the network card
    • Remove the two wires (inside the green circle)
    • the wires are very fragile and need to be removed with care
  4. Network card Replacement, Remove the network card: step 4, image 1 of 1
    • Place the spudger as shown in the photo. The network card will pop up. After that you can remove it and replace it with another one
    • The wires are very fragile, be aware!
Robin Koch
286 Reputation
2 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 737
