Nespresso Vertuo Next Power Button Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
5
Past 7 Days:
27
Past 30 Days:
141
All Time:
1,598
Comments: 4
4 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 40 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
Use this guide if you have a non-working or malfunctioning power button in your Nespresso Vertuo Next. The power button is used to power on and off the machine, as well as brew coffee and descale the machine. Without the power button you would never be able to use the machine, and if the button is malfunctioning, the machine would turn on and off at random moments, as well as brew coffee at random moments.
Before you remove and replace the power button, ensure that there is a direct source of electricity to the machine. If the power supply is faulty, the machine will not turn on. Also ensure that there is no damage in the wires connecting the button to the circuitry of the machine. If no damage can be located, then the power button is the most likely candidate for the problem and will need to be replaced. Before replacing, check to make sure the device is fully disconnected from any source.
Tools
    1. Nespresso Vertuo Next Power Button Replacement, Power Button: step 1, image 1 of 2 Nespresso Vertuo Next Power Button Replacement, Power Button: step 1, image 2 of 2
      • Side an opening tool in between where the top cover meets the white head piece and apply force to push the cover off.
      • Remove the cover from the device.
      Ask FixBot
    2. Nespresso Vertuo Next Power Button Replacement: step 2, image 1 of 2 Nespresso Vertuo Next Power Button Replacement: step 2, image 2 of 2
      • Use a T19 Torx screwdriver to remove the white top cover of the machine.
      • While pulling away the top cover, ensure that you don't pull out any wires or other parts.
      Ask FixBot
    3. Nespresso Vertuo Next Power Button Replacement: step 3, image 1 of 2 Nespresso Vertuo Next Power Button Replacement: step 3, image 2 of 2
      • Pop out the power button by pressing your thumb on the button and pressing down.
      Ask FixBot
    4. Nespresso Vertuo Next Power Button Replacement: step 4, image 1 of 2 Nespresso Vertuo Next Power Button Replacement: step 4, image 2 of 2
      • Use tweezers to unplug the wires from the power button.
      • Apply slight force and carefully pull the wire out as to not damage any pins.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Philip_S
440 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 141
All Time: 1,598
