Neo3Do Wire Replacement
  1. Neo3Do Wire Replacement, Back Panel: step 1, image 1 of 3 Neo3Do Wire Replacement, Back Panel: step 1, image 2 of 3 Neo3Do Wire Replacement, Back Panel: step 1, image 3 of 3
    • Turn the Neo3DO face down so that the logo is facing toward you.
    • Insert the plastic opening tool between the metal frame and the plastic back panel, as shown.
  2. Neo3Do Wire Replacement: step 2, image 1 of 2 Neo3Do Wire Replacement: step 2, image 2 of 2
    • Gently pry the back panel upwards.
    • Ensure the tool does not slip into the device and damage the internals.
  3. Neo3Do Wire Replacement: step 3, image 1 of 2 Neo3Do Wire Replacement: step 3, image 2 of 2
    • Once the back panel has been pried away from the bottom and sides of the Neo3DO, lift the back panel up and away from the tablet.
  4. Neo3Do Wire Replacement: step 4, image 1 of 1
    • When replacing the back panel, place the top edge of the back panel against the top edge of the Neo3DO, as shown.
    • The top edge of the device is the edge closest to the camera. The top of the back panel is the side with the hole for the camera.
  5. Neo3Do Wire Replacement, Wire: step 5, image 1 of 3 Neo3Do Wire Replacement, Wire: step 5, image 2 of 3 Neo3Do Wire Replacement, Wire: step 5, image 3 of 3
    • Starting with an open back panel, take your tweezers and use them to pull back the black tabs on the connector.
  6. Neo3Do Wire Replacement: step 6, image 1 of 1
    • Pull the wire completely from the socket.
    • Check the metallic parts for signs of damage or corrosion. If either exists, you might need to replace the battery entirely.
  7. Neo3Do Wire Replacement: step 7, image 1 of 1
    • Re-insert the wire into the socket.
  8. Neo3Do Wire Replacement: step 8, image 1 of 3 Neo3Do Wire Replacement: step 8, image 2 of 3 Neo3Do Wire Replacement: step 8, image 3 of 3
    • Using the tweezers, push the black tabs back in.
Michael Whitehead
201 Reputation
2 Guides authored
USF Tampa, Team 14-3, Eyestone Fall 2016 Member of USF Tampa, Team 14-3, Eyestone Fall 2016
USFT-EYESTONE-F16S14G3
3 Members
12 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 121
