Motorola i90c Midframe Replacement
    1. Motorola i90c Midframe Replacement, Battery: step 1, image 1 of 3 Motorola i90c Midframe Replacement, Battery: step 1, image 2 of 3 Motorola i90c Midframe Replacement, Battery: step 1, image 3 of 3
      • Slide the notch downward while pulling the back cover off to remove it.
      Ask FixBot
    2. Motorola i90c Midframe Replacement: step 2, image 1 of 3 Motorola i90c Midframe Replacement: step 2, image 2 of 3 Motorola i90c Midframe Replacement: step 2, image 3 of 3
      • Use your fingers to push the battery upward from the bottom.
      • Lift upwards to remove the battery.
      Ask FixBot
    1. Motorola i90c Midframe Replacement, Antenna: step 3, image 1 of 2 Motorola i90c Midframe Replacement, Antenna: step 3, image 2 of 2
      • Unscrew the antenna in a counter-clockwise fashion.
      • Remove the aluminum cover.
      Ask FixBot
    1. Motorola i90c Midframe Replacement, Midframe: step 4, image 1 of 3 Motorola i90c Midframe Replacement, Midframe: step 4, image 2 of 3 Motorola i90c Midframe Replacement, Midframe: step 4, image 3 of 3
      • Unscrew the 3 screws shown.
      • Lift the right part of the Nextel logo
      • Remove the screw underneath.
      Ask FixBot
    2. Motorola i90c Midframe Replacement: step 5, image 1 of 2 Motorola i90c Midframe Replacement: step 5, image 2 of 2
      • Forcing the cover off could damage the ribbon cable, so be careful when doing so.
      • Gently lift the back cover off.
      Ask FixBot
    3. Motorola i90c Midframe Replacement: step 6, image 1 of 3 Motorola i90c Midframe Replacement: step 6, image 2 of 3 Motorola i90c Midframe Replacement: step 6, image 3 of 3
      • Find the connection between the headphone jack and logic board.
      • Begin separating the two pieces, slowly and carefully.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Grant Glazebrook
7 Reputation
2 Guides authored
Cal Poly, Team 29-61, Johann Spring 2010 Member of Cal Poly, Team 29-61, Johann Spring 2010
CPSU-JOHANN-S10S29G61
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 8
Past 30 Days: 26
All Time: 1,744
