Motorola V557 Rear Casing Replacement
  1. Motorola V557 Rear Casing Replacement, Battery: step 1, image 1 of 3 Motorola V557 Rear Casing Replacement, Battery: step 1, image 2 of 3 Motorola V557 Rear Casing Replacement, Battery: step 1, image 3 of 3
    • First, on the back of the phone find the silver button on the top left corner of the phone.
    • Simultaneously push down the button and slide the back plate down to reveal the battery.
  2. Motorola V557 Rear Casing Replacement: step 2, image 1 of 2 Motorola V557 Rear Casing Replacement: step 2, image 2 of 2
    • Grab the lower edge of the battery at the two bottom corners.
    • Pull upward on the edges to remove the battery.
  3. Motorola V557 Rear Casing Replacement, SIM Card: step 3, image 1 of 3 Motorola V557 Rear Casing Replacement, SIM Card: step 3, image 2 of 3 Motorola V557 Rear Casing Replacement, SIM Card: step 3, image 3 of 3
    • Push the metal slider towards the top of the phone until it clicks out of the original position.
    • Gently slide out and remove the SIM card.
  4. Motorola V557 Rear Casing Replacement, Antenna: step 4, image 1 of 2 Motorola V557 Rear Casing Replacement, Antenna: step 4, image 2 of 2
    • Grip the antenna and twist it counterclockwise to loosen it.
    • When it has been loosened all the way, pull gently to remove the antenna piece.
  5. Motorola V557 Rear Casing Replacement, Rear Casing: step 5, image 1 of 3 Motorola V557 Rear Casing Replacement, Rear Casing: step 5, image 2 of 3 Motorola V557 Rear Casing Replacement, Rear Casing: step 5, image 3 of 3
    • Remove the screw covers over the two top screws by prying gently with a pin.
    • The large cover in the upper left of the back plate has no screw behind it, so should not be removed.
  6. Motorola V557 Rear Casing Replacement: step 6, image 1 of 3 Motorola V557 Rear Casing Replacement: step 6, image 2 of 3 Motorola V557 Rear Casing Replacement: step 6, image 3 of 3
    • Remove all four 6.0 mm Torx screws.
  7. Motorola V557 Rear Casing Replacement: step 7, image 1 of 3 Motorola V557 Rear Casing Replacement: step 7, image 2 of 3 Motorola V557 Rear Casing Replacement: step 7, image 3 of 3
    • Insert a spudger into marked holes, one at a time, and pry away from the phone to release internal tabs.
    • Separate and detach the rear casing.
Alex Georges
40 Reputation
4 Guides authored
Cal Poly, Team 7-50, Amido Fall 2010 Member of Cal Poly, Team 7-50, Amido Fall 2010
CPSU-AMIDO-F10S7G50
4 Members
24 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 1,360
