Motorola V400 Camera Replacement
  1. Motorola V400 Camera Replacement, Camera: step 1, image 1 of 3 Motorola V400 Camera Replacement, Camera: step 1, image 2 of 3 Motorola V400 Camera Replacement, Camera: step 1, image 3 of 3
    • First, gather your tools.
    • Tweezers
    • T6 Torx driver
    • Plastic opening tool
  2. Motorola V400 Camera Replacement: step 2, image 1 of 3 Motorola V400 Camera Replacement: step 2, image 2 of 3 Motorola V400 Camera Replacement: step 2, image 3 of 3
    • Take out the battery first!!!
    • Remove the four rubber stoppers around the main screen with tweezers.
  3. Motorola V400 Camera Replacement: step 3, image 1 of 3 Motorola V400 Camera Replacement: step 3, image 2 of 3 Motorola V400 Camera Replacement: step 3, image 3 of 3
    • Use a Torx T-6 Screwdriver to unscrew the 4 screws around the screen.
    • Note that the top screws are black the the bottom screws are silver and that they are different lengths.
  4. Motorola V400 Camera Replacement: step 4, image 1 of 3 Motorola V400 Camera Replacement: step 4, image 2 of 3 Motorola V400 Camera Replacement: step 4, image 3 of 3
    • Use a plastic opening tool to separate outer shell from metal interior cover by sliding it along the crease in the case.
    • To easily take off the case close the phone before trying to remove it.
  5. Motorola V400 Camera Replacement: step 5, image 1 of 3 Motorola V400 Camera Replacement: step 5, image 2 of 3 Motorola V400 Camera Replacement: step 5, image 3 of 3
    • Use a plastic opening tool to separate the inner metal cover from the circuit board. Apply pressure to remove the piece.
  6. Motorola V400 Camera Replacement: step 6, image 1 of 3 Motorola V400 Camera Replacement: step 6, image 2 of 3 Motorola V400 Camera Replacement: step 6, image 3 of 3
    • Remove rubber covering over the camera.
    • Carefully remove camera and the attached orange ribbon by gently pulling on it. Pull out in the direction of the blue arrow. You can use your fingers or tweezers.
Brian Avsec
1 Reputation
1 Guide authored
Ohio State, Team 1-1, Garvin Spring 2016 Member of Ohio State, Team 1-1, Garvin Spring 2016
OSU-GARVIN-S16S1G1
4 Members
2 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 8
All Time: 259
