Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a plastic opening tool.
Use a plastic opening tool to pry the antenna cable connectors from its respective socket on the motherboard.
De-route the antenna cable by pulling it out.
Use a spudger to lift and remove the black plastic screw cover at the bottom of the phone near the speaker
The cover is attached by adhesive, so some force may be required.
Insert the flat end of a spudger and pry the frame off the phone.
The frame is attached by adhesive, so some force may be required
