Introduction
Prereq-only to open the Motorola Moto Z Force Droid.
Apply a heated iOpener to the lower glass panel on the back of the phone for five minutes.
Insert an opening pick into the small gap between the rear case and the glass panel.
With tip of the pick under the glass panel, carefully pry upward to slightly separate the rear case and the panel.
Slide the pick in between the panel and the rear case.
Slide the pick across the length of the panel to slice the adhesive holding it to the rear case.
Insert the point of a spudger into the hole in the bottom right corner of the rear case.
Press the spudger into the hole to separate the display from the rear case.
Use a finger to maintain separation between the display assembly and the rear case while you remove the spudger.
Reinsert the flat end of the spudger in the gap between the display assembly and the rear case.
Slide the spudger along the side of the phone until you get to the clip securing the display to the rear case.
With the spudger right next to the clip, twist the spudger to pry the display away from the rear case and release the clip.
Tilt the top right corner of the display down to disengage one of the tabs that secure the top of the display.
Tilt the other corner down next, to disengage the other tab.
Lift the right edge of the display to hinge the phone open like a book, no more than 45°.
Gently lift the display enough to clear the clip from the edge of the rear case, maintaining the 45º angle.
Rest the display on the table behind the phone and open to 90º to allow access to the display cable.
