Motorola Moto G7 Play Front Facing Camera Replacement
  1. Motorola Moto G7 Play Front Facing Camera Replacement, Back Cover: step 1, image 1 of 2 Motorola Moto G7 Play Front Facing Camera Replacement, Back Cover: step 1, image 2 of 2
    • Turn off your device before you begin.
    • Use the iFixit pick to break the adhesive around the back case.
    • Use a heat gun, hairdryer, or iOpener to weaken the adhesive around the back case. If you're using the iOpener, please review the instructions for proper use.
  2. Motorola Moto G7 Play Front Facing Camera Replacement: step 2, image 1 of 1
    • Detach the back case from the phone.
    • Make sure the back is opened right to left so the cable of the fingerprint scanner does not get damaged.
  3. Motorola Moto G7 Play Front Facing Camera Replacement: step 3, image 1 of 2 Motorola Moto G7 Play Front Facing Camera Replacement: step 3, image 2 of 2
    • Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
  4. Motorola Moto G7 Play Front Facing Camera Replacement, Motherboard: step 4, image 1 of 1
    • Remove the nine 3.2mm screws from the motherboard cover with a Phillips #00 screwdriver.
  5. Motorola Moto G7 Play Front Facing Camera Replacement: step 5, image 1 of 1
    • Lift motherboard cover off by the bottom.
    • Use reverse tweezers or a similar tool if needed.
  6. Motorola Moto G7 Play Front Facing Camera Replacement: step 6, image 1 of 2 Motorola Moto G7 Play Front Facing Camera Replacement: step 6, image 2 of 2
    • Once the motherboard cover is removed, disconnect the four ribbon cables and the two wires attached to the motherboard.
  7. Motorola Moto G7 Play Front Facing Camera Replacement: step 7, image 1 of 2 Motorola Moto G7 Play Front Facing Camera Replacement: step 7, image 2 of 2
    • Using the Phillips #00 screwdriver, remove the single 0.4 mm black screw in the center of the motherboard.
    • Remove the motherboard from the device.
  8. Motorola Moto G7 Play Front Facing Camera Replacement, Front Facing Camera: step 8, image 1 of 1
    • Separate the front facing camera from the motherboard while removing the adhesive .
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 358
