Introduction
The battery on this phone is under the motherboard and will require the removal of the display, few screws, connectors and plastic parts.
If your battery is swollen, take appropriate precautions.
Parts
Once display is fully unglued from the frame, carefully lift it up and locate the display connector.
Using the same small plastic tool, carefully remove the yellow tape off the connector.
Now carefully undo the black connector lock by lifting it up in the direction of the red arrow.
Lastly slide the display cable off the connector. It should easily slide off, if not make sure the black lock is fully unlatched.
Now that the display is out, remove the aluminum shield off the motherboard.
Unscrew the single 4mm screw located on the top using a T4 Torx bit.
After screw is out, gently remove the aluminum shield off the motherboard.
After the battery cable is disconnected from the motherboard, use the metal spudger tool and carefully insert it in the small opening by the speaker and pry the motherboard up enough to fit your finger in between the motherboard and the phone frame.
Now just pull the motherboard starting from the top to bottom off the phone case.
Use a spudger to gently pry up the battery.
Obtain a new battery and place it into the plastic casing using double sided tape or whatever is provided with the new battery.
39 other people completed this guide.
9 Comments
My bettri chanj
My bettri chanj ani problam
my mobile auto shutdown currunt working
