Introduction
Like most smartphones, the battery can deteriorate after some years of use. If you're experiencing battery drainage, the power is draining much faster than expected, or the phone simply won't hold a charge, a faulty battery might be the cause.
To be sure, time how long your battery lasts after a full charge, then compare how long that battery lasted versus its advertised battery life. If it doesn't match up, then you have a bad battery.
Ensure that the device is fully powered down and not connected to any external power source.
Use an iOpener or hair dryer to heat the perimeter of the back cover to loosen the adhesive beneath.
Insert the tip of an opening pick 2-3 mm into the seam between the back cover and chassis.
Slide the pick around the entire perimeter of the case to sever the adhesive, inserting additional opening picks periodically to prevent the back cover from resealing.
Remove the back cover.
Remove the following T3 Torx screws:
Ten 6 mm silver screws
Six 5 mm black screws
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
