Motorola Edge (2021) Front-Facing Camera module Replacement
    1. Motorola Edge (2021) Front-Facing Camera module Replacement, Front-Facing Camera: step 1, image 1 of 1
      • Remove the back cover of the smartphone.
      Ask FixBot
    2. Motorola Edge (2021) Front-Facing Camera module Replacement: step 2, image 1 of 1
      • Use two iOpeners to heat up the glue beneath the back-plate.
      Ask FixBot
    3. Motorola Edge (2021) Front-Facing Camera module Replacement: step 3, image 1 of 3 Motorola Edge (2021) Front-Facing Camera module Replacement: step 3, image 2 of 3 Motorola Edge (2021) Front-Facing Camera module Replacement: step 3, image 3 of 3
      • Wedge the iFixit Opening Pick in between the cracks of the smartphone's backplate.
      • Slide the opening tool along the sides of the phone until the glue is separated from the back-plate.
      Ask FixBot
    4. Motorola Edge (2021) Front-Facing Camera module Replacement: step 4, image 1 of 2 Motorola Edge (2021) Front-Facing Camera module Replacement: step 4, image 2 of 2
      • Next, use the Phillips #00 Screwdriver to unscrew the motherboard/camera casing. Be sure to check under the glue for any unseen screws.
      Ask FixBot
    5. Motorola Edge (2021) Front-Facing Camera module Replacement: step 5, image 1 of 2 Motorola Edge (2021) Front-Facing Camera module Replacement: step 5, image 2 of 2
      • After you're done unscrewing, use the iFixit Opening Tool to carefully pry open the casing.
      Ask FixBot
    6. Motorola Edge (2021) Front-Facing Camera module Replacement: step 6, image 1 of 1
      • This is the front facing camera module.
      Ask FixBot
    7. Motorola Edge (2021) Front-Facing Camera module Replacement: step 7, image 1 of 2 Motorola Edge (2021) Front-Facing Camera module Replacement: step 7, image 2 of 2
      • Using the iFixit Opening Tool, carefully remove the camera module.
      Ask FixBot
    8. Motorola Edge (2021) Front-Facing Camera module Replacement: step 8, image 1 of 1
      • Congratulations, you have successfully removed the front facing camera module for your Motorola Edge.
      Ask FixBot
Jaier
339 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 35
All Time: 470
