Motorola Droid Turbo Headphone Jack Replacement
  1. Motorola Droid Turbo Headphone Jack Replacement, Rear Case: step 1, image 1 of 1
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
  2. Motorola Droid Turbo Headphone Jack Replacement: step 2, image 1 of 2 Motorola Droid Turbo Headphone Jack Replacement: step 2, image 2 of 2
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
  3. Motorola Droid Turbo Headphone Jack Replacement, Midframe: step 3, image 1 of 1
    • Remove the midframe bezel.
  4. Motorola Droid Turbo Headphone Jack Replacement: step 4, image 1 of 1
    • Remove the four Torx T5 screws securing the midframe plate.
  5. Motorola Droid Turbo Headphone Jack Replacement: step 5, image 1 of 1
    • Remove the midframe.
  6. Motorola Droid Turbo Headphone Jack Replacement, Headphone Jack: step 6, image 1 of 2 Motorola Droid Turbo Headphone Jack Replacement, Headphone Jack: step 6, image 2 of 2
    • Insert the pointed end of a spudger into the headphone jack, and gently pry the jack up and away from the midframe.
Geoff Wacker
90,075 Reputation
89 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 3,304
