Introduction
Give life back to your Droid RAZR with a new battery.
If your battery is swollen, take appropriate precautions.
Insert a plastic opening tool between the back cover and rear case at the lower left edge of the back cover.
Pry the back cover up with the plastic opening tool to free the plastic clips.
Continue prying along the left edge of the back cover towards the top of the phone.
Work the plastic opening tool across the top of the back case to free the plastic clips.
Continue prying down the right side of the back cover to free the remaining clips.
Use the tip of a spudger to lift up the red silicone cover over the battery terminal screws and remove it.
Remove the two 3.3 mm T5 Torx battery terminal screws.
Grab the blue battery removal tab and lift the battery out to remove it.
