Moto C Plus Motherboard Assembly Replacement
  1. Moto C Plus Motherboard Assembly Replacement, Back Cover: step 1, image 1 of 3 Moto C Plus Motherboard Assembly Replacement, Back Cover: step 1, image 2 of 3 Moto C Plus Motherboard Assembly Replacement, Back Cover: step 1, image 3 of 3
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or spudger, into the notch on the bottom right to start separating the phone unit from the back cover.
    • Move to the bottom left corner and pry the phone unit out of the back cover until you can get a good grip.
  2. Moto C Plus Motherboard Assembly Replacement: step 2, image 1 of 2 Moto C Plus Motherboard Assembly Replacement: step 2, image 2 of 2
    • Lift the phone out of the back cover.
  3. Moto C Plus Motherboard Assembly Replacement, Battery: step 3, image 1 of 3 Moto C Plus Motherboard Assembly Replacement, Battery: step 3, image 2 of 3 Moto C Plus Motherboard Assembly Replacement, Battery: step 3, image 3 of 3
    • Use a spudger or fingernail to lift the battery starting at the notch on the bottom left.
    • Lever the battery out of its recess and remove it.
  4. Moto C Plus Motherboard Assembly Replacement, Motherboard Cover: step 4, image 1 of 1
    • Remove the five 3.1 mm long Phillips #00 screws.
  5. Moto C Plus Motherboard Assembly Replacement: step 5, image 1 of 3 Moto C Plus Motherboard Assembly Replacement: step 5, image 2 of 3 Moto C Plus Motherboard Assembly Replacement: step 5, image 3 of 3
    • Apply an opening pick to the bottom right corner of the motherboard cover.
    • Twist the opening pick to free the motherboard cover out of the plastic clamps on the right side of the phone.
  6. Moto C Plus Motherboard Assembly Replacement: step 6, image 1 of 2 Moto C Plus Motherboard Assembly Replacement: step 6, image 2 of 2
    • Repeat the previous step on the left side of the motherboard cover to free it out of the plastic clamps.
    • Pry up the motherboard cover until you can get a good grip.
    • Remove the motherboard cover.
  7. Moto C Plus Motherboard Assembly Replacement, Motherboard Assembly: step 7, image 1 of 1
    • Remove the two Phillips #00 screws (3.2 mm length).
  8. Moto C Plus Motherboard Assembly Replacement: step 8, image 1 of 2 Moto C Plus Motherboard Assembly Replacement: step 8, image 2 of 2
    • Use the tip of a spudger to open the power and volume button ZIF connector by lifting the black flap.
  9. Moto C Plus Motherboard Assembly Replacement: step 9, image 1 of 2 Moto C Plus Motherboard Assembly Replacement: step 9, image 2 of 2
    • Use a pair of tweezers to pull the power and volume button flex cable out of the ZIF connector.
    • Fold the power and volume button flex cable out of the way.
  10. Moto C Plus Motherboard Assembly Replacement: step 10, image 1 of 2 Moto C Plus Motherboard Assembly Replacement: step 10, image 2 of 2
    • Use a pair of tweezers to pry up and disconnect the antenna cable.
    • Fold the antenna cable out of the way.
  11. Moto C Plus Motherboard Assembly Replacement: step 11, image 1 of 2 Moto C Plus Motherboard Assembly Replacement: step 11, image 2 of 2
    • Use the tip of a spudger to open the interconnect cable ZIF connector by lifting the brown flap.
    • When reassembling make sure the white line on the cable aligns with the closed flap.
  12. Moto C Plus Motherboard Assembly Replacement: step 12, image 1 of 2 Moto C Plus Motherboard Assembly Replacement: step 12, image 2 of 2
    • Use a pair of tweezers to pull the interconnect flex cable out of the ZIF connector.
  13. Moto C Plus Motherboard Assembly Replacement: step 13, image 1 of 2 Moto C Plus Motherboard Assembly Replacement: step 13, image 2 of 2
    • Use the tip of a spudger to open the flap of the ZIF connector next to the headphone jack.
  14. Moto C Plus Motherboard Assembly Replacement: step 14, image 1 of 2 Moto C Plus Motherboard Assembly Replacement: step 14, image 2 of 2
    • Use a pair of tweezers to pull the flex cable out of the ZIF connector.
  15. Moto C Plus Motherboard Assembly Replacement: step 15, image 1 of 2 Moto C Plus Motherboard Assembly Replacement: step 15, image 2 of 2
    • Don't try to remove the motherboard all the way yet. The display flex cable is still connected to its rear side.
    • Use a spudger to carefully lift the motherboard until you can get a good grip. Avoid to damage the cables next to the motherboard.
    • Lift the motherboard and fold it back until you have enough space to disconnect the display flex cable.
  16. Moto C Plus Motherboard Assembly Replacement: step 16, image 1 of 2 Moto C Plus Motherboard Assembly Replacement: step 16, image 2 of 2
    • Use the edge of a spudger to pry up and disconnect the display flex cable from the motherboard.
  17. Moto C Plus Motherboard Assembly Replacement: step 17, image 1 of 1
    • Remove the motherboard.
Dominik Schnabelrauch
206,467 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,524 Guides authored
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 40
All Time: 6,367
