Installing Motion Computing LE1600 Display Screen
  1. Installing Motion Computing LE1600 Display Screen, Battery: step 1, image 1 of 1
    • Turn the device so the screen is facing down.
  2. Installing Motion Computing LE1600 Display Screen: step 2, image 1 of 2 Installing Motion Computing LE1600 Display Screen: step 2, image 2 of 2
    • Slide the battery lock switch next to the power slider to the unlocked position.
  3. Installing Motion Computing LE1600 Display Screen: step 3, image 1 of 3 Installing Motion Computing LE1600 Display Screen: step 3, image 2 of 3 Installing Motion Computing LE1600 Display Screen: step 3, image 3 of 3
    • Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet.
    • When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place.
  4. Installing Motion Computing LE1600 Display Screen, Display Screen: step 4, image 1 of 1
    • Unscrew hard drive panel using a Phillips head #1 screwdriver.
    • (Our device was not given to us with a hard drive or a hard drive panel)
  5. Installing Motion Computing LE1600 Display Screen: step 5, image 1 of 3 Installing Motion Computing LE1600 Display Screen: step 5, image 2 of 3 Installing Motion Computing LE1600 Display Screen: step 5, image 3 of 3
    • Pull clear plastic tab to detach hard drive from tablet.
  6. Installing Motion Computing LE1600 Display Screen: step 6, image 1 of 2 Installing Motion Computing LE1600 Display Screen: step 6, image 2 of 2
    • To disconnect the three white ribbon cables on the side closest to the hard drive connector, pull the white plastic tabs.
  7. Installing Motion Computing LE1600 Display Screen: step 7, image 1 of 1
    • Pull the brown tabs to disconnect the white ribbon cable on the other side.
  8. Installing Motion Computing LE1600 Display Screen: step 8, image 1 of 2 Installing Motion Computing LE1600 Display Screen: step 8, image 2 of 2
    • Caution: do not pull on the wires, instead pull from the plastic connectors.
    • To disconnect the remaining ribbon cables, pull the plastic connectors away from their connections.
  9. Installing Motion Computing LE1600 Display Screen: step 9, image 1 of 1
    • With a Phillips #1 screwdriver, Unscrew the nine 10mm screws holding the case together.
  10. Installing Motion Computing LE1600 Display Screen: step 10, image 1 of 2 Installing Motion Computing LE1600 Display Screen: step 10, image 2 of 2
    • Using a spudger, press in the five tabs on the side where the battery was.
    • This should separate the two halves of the device. Carefully set the side with the motherboard off to the side.
  11. Installing Motion Computing LE1600 Display Screen: step 11, image 1 of 2 Installing Motion Computing LE1600 Display Screen: step 11, image 2 of 2
    • Unplug the three ribbon cables by pulling on the brown tabs and unplugging cable.
  12. Installing Motion Computing LE1600 Display Screen: step 12, image 1 of 2 Installing Motion Computing LE1600 Display Screen: step 12, image 2 of 2
    • With a Phillips #1 screwdriver, unscrew the three 4mm screws holding the display bracket on the back side of the front buttons.
  13. Installing Motion Computing LE1600 Display Screen: step 13, image 1 of 3 Installing Motion Computing LE1600 Display Screen: step 13, image 2 of 3 Installing Motion Computing LE1600 Display Screen: step 13, image 3 of 3
    • On the bracket behind the fingerprint scanner, unscrew the two 4mm screws holding it to the display with a Phillips #1 screwdriver.
    • Fold away right bracket from display.
  14. Installing Motion Computing LE1600 Display Screen: step 14, image 1 of 2 Installing Motion Computing LE1600 Display Screen: step 14, image 2 of 2
    • Pull the plastic case away from the display screen.
Jesse Graham
45 Reputation
1 Guide authored
Cal Poly, Team 15-14, Forte Spring 2012 Member of Cal Poly, Team 15-14, Forte Spring 2012
CPSU-FORTE-S12S15G14
5 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 20
All Time: 3,569
