Introduction
If your screen cracks or one of the pixels no longer functions correctly, you may need to replace the display screen. This guide will take you through the process of removing and replacing the display screen of the LE1600.
Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet.
Unscrew hard drive panel using a Phillips head #1 screwdriver.
(Our device was not given to us with a hard drive or a hard drive panel)
To disconnect the three white ribbon cables on the right, pull the white plastic tabs on the connectors to the left.
Next, to disconnect the white ribbon cable on the left, pull the brown tabs and detach as you did before.
Using a spudger, press in the five tabs keeping the two halves together, set the half with the motherboard off to the side.
With a Phillips #1 screw driver, unscrew the three screws holding the left bracket of the display.
On the right bracket, unscrew the two 4mm screws holding it to the display with a Phillips #1 screwdriver.
Fold away right bracket from display.
