Microsoft Surface Pro 7+ SSD Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
6
Past 7 Days:
89
Past 30 Days:
398
All Time:
1,606
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Follow this guide to replace or upgrade the SSD in your Microsoft Surface Pro 7+ tablet.
Before starting this repair, read through Microsoft's guide on best practices for SSD removal. If your replacement SSD has data on it, make a backup of the drive before installing it.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
  • Surface Pro 7+ SSD - Genuine
    4.8
    View
Parts
    4.8
    View
Tools
    1. Microsoft Surface Pro 7+ SSD Replacement, Before you begin: step 1, image 1 of 1
      • Before starting your repair, unplug all cables and fully shut down your Surface Pro.
      Ask FixBot
    1. Microsoft Surface Pro 7+ SSD Replacement, Open the kickstand: step 2, image 1 of 2 Microsoft Surface Pro 7+ SSD Replacement, Open the kickstand: step 2, image 2 of 2
      • Open the kickstand to about 90 degrees.
      Ask FixBot
    1. Microsoft Surface Pro 7+ SSD Replacement, Remove the SSD door: step 3, image 1 of 3 Microsoft Surface Pro 7+ SSD Replacement, Remove the SSD door: step 3, image 2 of 3 Microsoft Surface Pro 7+ SSD Replacement, Remove the SSD door: step 3, image 3 of 3
      • Firmly press a SIM eject tool into the small hole in the corner of the SSD door until it pops up.
      • Alternatively, you can also use a small, straightened paper clip.
      • Remove the SSD door.
      Ask FixBot
    1. Microsoft Surface Pro 7+ SSD Replacement, Remove the SSD screw: step 4, image 1 of 2 Microsoft Surface Pro 7+ SSD Replacement, Remove the SSD screw: step 4, image 2 of 2
      • Removing the SSD also functions as a battery disconnect and should be done before all major repairs.
      • Use a Torx Plus 3IP screwdriver to remove the 2.2 mm‑long screw securing the SSD.
      Ask FixBot
    2. Microsoft Surface Pro 7+ SSD Replacement, Remove the SSD: step 5, image 1 of 2 Microsoft Surface Pro 7+ SSD Replacement, Remove the SSD: step 5, image 2 of 2
      • Don't pull up at a sharp angle, or you may damage the SSD and its socket.
      • Use your fingers to pull the SSD out of its socket at a shallow angle.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Once your laptop is reassembled, follow Microsoft's post SSD replacement guide.
Spencer Day
207,305 Reputation
1,266 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 89
Past 30 Days: 398
All Time: 1,606
