Microsoft Surface Pro 5 Charging Port Replacement
  1. Microsoft Surface Pro 5 Charging Port Replacement, Disconnect the display board: step 1, image 1 of 3 Microsoft Surface Pro 5 Charging Port Replacement, Disconnect the display board: step 1, image 2 of 3 Microsoft Surface Pro 5 Charging Port Replacement, Disconnect the display board: step 1, image 3 of 3
    • Use a spudger to flip up the small locking flaps on the display cable ZIF connectors.
  2. Microsoft Surface Pro 5 Charging Port Replacement: step 2, image 1 of 3 Microsoft Surface Pro 5 Charging Port Replacement: step 2, image 2 of 3 Microsoft Surface Pro 5 Charging Port Replacement: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to slide the display cables straight out of their sockets on the display board.
  3. Microsoft Surface Pro 5 Charging Port Replacement, Remove the display board: step 3, image 1 of 3 Microsoft Surface Pro 5 Charging Port Replacement, Remove the display board: step 3, image 2 of 3 Microsoft Surface Pro 5 Charging Port Replacement, Remove the display board: step 3, image 3 of 3
    • Slide an opening pick under the display board to separate the adhesive holding it onto the back of the screen.
  4. Microsoft Surface Pro 5 Charging Port Replacement: step 4, image 1 of 1
    Tesa 61395 Tape
    $5.99
    Buy
    • Remove the display board.
    • During reassembly, use a strong double-sided tape or a precut adhesive card to secure the display board. Clean off the old adhesive before applying new adhesive.
    • To ensure correct positioning, plug in both display connectors before adhering the board to the display.
  5. Microsoft Surface Pro 5 Charging Port Replacement: step 5, image 1 of 1
    • Only the screen remains.
  6. Microsoft Surface Pro 5 Charging Port Replacement, Remove the heat sink shield: step 6, image 1 of 2 Microsoft Surface Pro 5 Charging Port Replacement, Remove the heat sink shield: step 6, image 2 of 2
    Buy
    • Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the heat sink.
    • Use the tweezers to pry the EMI shield away from the motherboard as much as you can without bending it. Do not remove it yet.
    • Try not to deform the shield too much—you will need to reinstall it during reassembly.
    • Take care not to puncture the battery with the tweezers while working on this shield.
  7. Microsoft Surface Pro 5 Charging Port Replacement: step 7, image 1 of 3 Microsoft Surface Pro 5 Charging Port Replacement: step 7, image 2 of 3 Microsoft Surface Pro 5 Charging Port Replacement: step 7, image 3 of 3
    • Repeat the last step for each corner of the EMI shield covering the heat sink.
  8. Microsoft Surface Pro 5 Charging Port Replacement: step 8, image 1 of 1
    • Remove the heat sink shield.
  9. Microsoft Surface Pro 5 Charging Port Replacement, Remove the heat sink: step 9, image 1 of 2 Microsoft Surface Pro 5 Charging Port Replacement, Remove the heat sink: step 9, image 2 of 2
    • Remove the ten Torx screws securing the heat sink:
    • Five 2.6 mm-long T3 screws
    • Four 3.3 mm-long T5 screws
    • During reassembly, tighten the heat sink screws in the following criss-cross pattern, one turn at a time, until they're tight:
    • Screw 1
    • Screw 2
    • Screw 3
    • Screw 4
  10. Microsoft Surface Pro 5 Charging Port Replacement: step 10, image 1 of 3 Microsoft Surface Pro 5 Charging Port Replacement: step 10, image 2 of 3 Microsoft Surface Pro 5 Charging Port Replacement: step 10, image 3 of 3
  11. Microsoft Surface Pro 5 Charging Port Replacement, Charging Port: step 11, image 1 of 1
    • Pry up the metal cover on the motherboard using either the nylon spudger or plastic opening tool.
  12. Microsoft Surface Pro 5 Charging Port Replacement: step 12, image 1 of 1
    • Use a T4 Torx driver to remove the two 3mm screws from the ribbon holder on top of the colored cables.
  13. Microsoft Surface Pro 5 Charging Port Replacement: step 13, image 1 of 1
    • Use a T4 Torx driver to remove the two 3mm screws holding the charging port assembly to the case.
  14. Microsoft Surface Pro 5 Charging Port Replacement: step 14, image 1 of 1
    • Use the nylon spudger to pop off the ribbon connector for the ribbon going over the charging port connection.
  15. Microsoft Surface Pro 5 Charging Port Replacement: step 15, image 1 of 1
    • Remove the ribbon by lifting up and sliding out the connector.
  16. Microsoft Surface Pro 5 Charging Port Replacement: step 16, image 1 of 1
    • Use the nylon spudger to pop up the clamp on the charging port connection.
  17. Microsoft Surface Pro 5 Charging Port Replacement: step 17, image 1 of 1
    • Grab the opened clamp on the charging port connecting cables and disconnect it by pulling back.
    • This may take some force to disconnect.
  18. Microsoft Surface Pro 5 Charging Port Replacement: step 18, image 1 of 1
    • Remove the charging port by pulling the connector in the direction of the batteries.
    • Pull carefully so that the cables do not get pulled out of the connector.
Kaden Foster
885 Reputation
3 Guides authored
Cal Poly, Team S15-G3, Livingston Fall 2017 Member of Cal Poly, Team S15-G3, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G3
3 Members
17 Guides authored
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 119
All Time: 9,780
