Microsoft Surface Pro 5 Motherboard Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Microsoft Surface Pro 5 Motherboard Replacement, Disconnect the display board: step 1, image 1 of 3 Microsoft Surface Pro 5 Motherboard Replacement, Disconnect the display board: step 1, image 2 of 3 Microsoft Surface Pro 5 Motherboard Replacement, Disconnect the display board: step 1, image 3 of 3
    • Use a spudger to flip up the small locking flaps on the display cable ZIF connectors.
  2. Microsoft Surface Pro 5 Motherboard Replacement: step 2, image 1 of 3 Microsoft Surface Pro 5 Motherboard Replacement: step 2, image 2 of 3 Microsoft Surface Pro 5 Motherboard Replacement: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to slide the display cables straight out of their sockets on the display board.
  3. Microsoft Surface Pro 5 Motherboard Replacement, Remove the display board: step 3, image 1 of 3 Microsoft Surface Pro 5 Motherboard Replacement, Remove the display board: step 3, image 2 of 3 Microsoft Surface Pro 5 Motherboard Replacement, Remove the display board: step 3, image 3 of 3
    • Slide an opening pick under the display board to separate the adhesive holding it onto the back of the screen.
  4. Microsoft Surface Pro 5 Motherboard Replacement: step 4, image 1 of 1
    Tesa 61395 Tape
    $5.99
    Buy
    • Remove the display board.
    • During reassembly, use a strong double-sided tape or a precut adhesive card to secure the display board. Clean off the old adhesive before applying new adhesive.
    • To ensure correct positioning, plug in both display connectors before adhering the board to the display.
  5. Microsoft Surface Pro 5 Motherboard Replacement: step 5, image 1 of 1
    • Only the screen remains.
  6. Microsoft Surface Pro 5 Motherboard Replacement, Remove the heat sink shield: step 6, image 1 of 2 Microsoft Surface Pro 5 Motherboard Replacement, Remove the heat sink shield: step 6, image 2 of 2
    Buy
    • Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the heat sink.
    • Use the tweezers to pry the EMI shield away from the motherboard as much as you can without bending it. Do not remove it yet.
    • Try not to deform the shield too much—you will need to reinstall it during reassembly.
    • Take care not to puncture the battery with the tweezers while working on this shield.
  7. Microsoft Surface Pro 5 Motherboard Replacement: step 7, image 1 of 3 Microsoft Surface Pro 5 Motherboard Replacement: step 7, image 2 of 3 Microsoft Surface Pro 5 Motherboard Replacement: step 7, image 3 of 3
    • Repeat the last step for each corner of the EMI shield covering the heat sink.
  8. Microsoft Surface Pro 5 Motherboard Replacement: step 8, image 1 of 1
    • Remove the heat sink shield.
  9. Microsoft Surface Pro 5 Motherboard Replacement, Remove the heat sink: step 9, image 1 of 2 Microsoft Surface Pro 5 Motherboard Replacement, Remove the heat sink: step 9, image 2 of 2
    • Remove the ten Torx screws securing the heat sink:
    • Five 2.6 mm-long T3 screws
    • Four 3.3 mm-long T5 screws
    • During reassembly, tighten the heat sink screws in the following criss-cross pattern, one turn at a time, until they're tight:
    • Screw 1
    • Screw 2
    • Screw 3
    • Screw 4
  10. Microsoft Surface Pro 5 Motherboard Replacement: step 10, image 1 of 3 Microsoft Surface Pro 5 Motherboard Replacement: step 10, image 2 of 3 Microsoft Surface Pro 5 Motherboard Replacement: step 10, image 3 of 3
  11. Microsoft Surface Pro 5 Motherboard Replacement, Front and Rear Camera: step 11, image 1 of 1
    • Pry off the metal cover covering the front and rear camera ribbon cable motherboard connections using a nylon spudger.
  12. Microsoft Surface Pro 5 Motherboard Replacement: step 12, image 1 of 1
    • Lift the front camera ribbon cable off the motherboard using the nylon spudger.
  13. Microsoft Surface Pro 5 Motherboard Replacement: step 13, image 1 of 1
    • Remove the front camera.
  14. Microsoft Surface Pro 5 Motherboard Replacement: step 14, image 1 of 1
    • Remove the two Torx T3 x 2.5mm screws holding down the rear camera.
  15. Microsoft Surface Pro 5 Motherboard Replacement: step 15, image 1 of 1
    • Lift the rear camera ribbon cable off the motherboard using the nylon spudger.
  16. Microsoft Surface Pro 5 Motherboard Replacement: step 16, image 1 of 1
    • Remove the rear camera.
  17. Microsoft Surface Pro 5 Motherboard Replacement, Disconnect the microSD card reader: step 17, image 1 of 3 Microsoft Surface Pro 5 Motherboard Replacement, Disconnect the microSD card reader: step 17, image 2 of 3 Microsoft Surface Pro 5 Motherboard Replacement, Disconnect the microSD card reader: step 17, image 3 of 3
    Buy
    • Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the microSD card reader connector.
    • Repeat this procedure at different points around the shield until it is free. Remove the shield.
  18. Microsoft Surface Pro 5 Motherboard Replacement: step 18, image 1 of 2 Microsoft Surface Pro 5 Motherboard Replacement: step 18, image 2 of 2
    • Use the flat end of a spudger to pry the microSD card reader connector up and out of its socket on the motherboard.
  19. Microsoft Surface Pro 5 Motherboard Replacement, Disconnect the SurfaceConnect port: step 19, image 1 of 2 Microsoft Surface Pro 5 Motherboard Replacement, Disconnect the SurfaceConnect port: step 19, image 2 of 2
    • Use the flat end of a spudger to lift the flap that sits over the SurfaceConnect port connector.
  20. Microsoft Surface Pro 5 Motherboard Replacement: step 20, image 1 of 2 Microsoft Surface Pro 5 Motherboard Replacement: step 20, image 2 of 2
    • Slide the SurfaceConnect port connector out of its socket on the motherboard.
  21. Microsoft Surface Pro 5 Motherboard Replacement, Remove the SurfaceConnect port: step 21, image 1 of 1
    • Use a T5 Torx driver to remove the two 3.7 mm screws securing the SurfaceConnect port.
  22. Microsoft Surface Pro 5 Motherboard Replacement: step 22, image 1 of 2 Microsoft Surface Pro 5 Motherboard Replacement: step 22, image 2 of 2
    • Gently pull the SurfaceConnect port out of its recess in the case and remove it.
  23. Microsoft Surface Pro 5 Motherboard Replacement, Disconnect the right speaker: step 23, image 1 of 2 Microsoft Surface Pro 5 Motherboard Replacement, Disconnect the right speaker: step 23, image 2 of 2
    • Use the point of a spudger to lift the right speaker connector up and out of its socket on the motherboard.
  24. Microsoft Surface Pro 5 Motherboard Replacement, Unscrew the speaker: step 24, image 1 of 1
    • Use a T5 Torx driver to remove the two screws securing the speaker:
    • One 6 mm screw
    • One 3.7 mm screw
  25. Microsoft Surface Pro 5 Motherboard Replacement, Remove the speaker: step 25, image 1 of 3 Microsoft Surface Pro 5 Motherboard Replacement, Remove the speaker: step 25, image 2 of 3 Microsoft Surface Pro 5 Motherboard Replacement, Remove the speaker: step 25, image 3 of 3
    • Use a spudger to lift the left edge of the speaker so that it clears the components around the speaker.
    • With the left edge lifted, slide the speaker to the left, straight out of its recess in the case.
  26. Microsoft Surface Pro 5 Motherboard Replacement, Camera Tie Bar: step 26, image 1 of 1
    • Remove the Torx T5 x 6mm screw connecting the black tie bar to the power button/volume control/speaker assembly.
  27. Microsoft Surface Pro 5 Motherboard Replacement: step 27, image 1 of 1
    • Remove the remaining three Torx T5 x 4.5mm screws holding down the camera tie bar.
  28. Microsoft Surface Pro 5 Motherboard Replacement: step 28, image 1 of 1
    Buy
    • Disconnect the small ribbon cable connecting the camera tie bar to the motherboard by pulling up with tweezers.
  29. Microsoft Surface Pro 5 Motherboard Replacement: step 29, image 1 of 1
    • Lift the camera tie bar off of the device.
  30. Microsoft Surface Pro 5 Motherboard Replacement, Motherboard: step 30, image 1 of 2 Microsoft Surface Pro 5 Motherboard Replacement, Motherboard: step 30, image 2 of 2
    • Disconnect the black and red cable connector and the ribbon from the motherboard that connect the power button assembly.
  31. Microsoft Surface Pro 5 Motherboard Replacement: step 31, image 1 of 2 Microsoft Surface Pro 5 Motherboard Replacement: step 31, image 2 of 2
    • Remove the eight 2.5 mm T3 screws from the motherboard.
  32. Microsoft Surface Pro 5 Motherboard Replacement: step 32, image 1 of 2 Microsoft Surface Pro 5 Motherboard Replacement: step 32, image 2 of 2
    • Use the plastic opening tool to pop up the connector going from the edge of the case to the motherboard.
    • Use a Torx T3 to remove the one 2.5 mm screw on the motherboard.
  33. Microsoft Surface Pro 5 Motherboard Replacement: step 33, image 1 of 1
    • Remove the motherboard by using a hand to lift up and move it to the right.
Kaden Foster
885 Reputation
3 Guides authored
Cal Poly, Team S15-G3, Livingston Fall 2017 Member of Cal Poly, Team S15-G3, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G3
3 Members
17 Guides authored
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 76
All Time: 13,478
