Microsoft Surface Pro 4 SSD Drive Replacement
  1. Microsoft Surface Pro 4 SSD Drive Replacement, SSD Drive: step 1, image 1 of 2 Microsoft Surface Pro 4 SSD Drive Replacement, SSD Drive: step 1, image 2 of 2
    • Use a blue plastic opening tool to pry around the edges of the metal shield covering the SSD drive.
  2. Microsoft Surface Pro 4 SSD Drive Replacement: step 2, image 1 of 2 Microsoft Surface Pro 4 SSD Drive Replacement: step 2, image 2 of 2
    • Remove the 1.0 mm Torx T4 screw holding down the SSD drive.
  3. Microsoft Surface Pro 4 SSD Drive Replacement: step 3, image 1 of 2 Microsoft Surface Pro 4 SSD Drive Replacement: step 3, image 2 of 2
    • Use a blue plastic opening tool or spudger to lift the SSD drive slightly and grasp it with your fingers. Pull the drive down towards yourself to remove it from the device.
StacyAnn Brown
3,916 Reputation
2 Guides authored
Metro State, Team 1-3, Carpenter Spring 2016 Member of Metro State, Team 1-3, Carpenter Spring 2016
MSU-CARPENTER-S16S1G3
2 Members
12 Guides authored
Past 24 Hours: 50
Past 7 Days: 369
Past 30 Days: 1,570
All Time: 256,449
