Microsoft Surface Pro 4 Battery Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
    1. Microsoft Surface Pro 4 Battery Replacement, Battery: step 1, image 1 of 1
      • Disconnect black wire from motherboard.
      Ask FixBot
    2. Microsoft Surface Pro 4 Battery Replacement: step 2, image 1 of 1
      • Remove the six 1.5 mm Torx T3 screws securing the motherboard.
      Ask FixBot
    3. Microsoft Surface Pro 4 Battery Replacement: step 3, image 1 of 1
      • Use plastic opening tool to remove metal casing at the bottom left corner of the motherboard.
      Ask FixBot
    4. Microsoft Surface Pro 4 Battery Replacement: step 4, image 1 of 1
      • Remove remaining screw.
      • 2.0 mm Torx T4 screw.
      Ask FixBot
    5. Microsoft Surface Pro 4 Battery Replacement: step 5, image 1 of 2 Microsoft Surface Pro 4 Battery Replacement: step 5, image 2 of 2
      • The battery is attached to the device by strong adhesive tape. Use a plastic opening tool to pry around the underside of the battery.
      • Peel the battery up and away from the bottom of the device.
      • Do not use metal tools for this step. the battery can leak harmful substances if punctured.
      Ask FixBot
    6. Microsoft Surface Pro 4 Battery Replacement: step 6, image 1 of 3 Microsoft Surface Pro 4 Battery Replacement: step 6, image 2 of 3 Microsoft Surface Pro 4 Battery Replacement: step 6, image 3 of 3
      • In order to prevent a short circuit, insert a piece of cardboard, paper or plastic between the battery connector and motherboard before sliding the battery cable out from under the motherboard.
      • Also be careful to protect the motherboard from shorts while placing the cable for the new battery.
      • Detach the battery from under the motherboard. Remove from the device.
      Ask FixBot
StacyAnn Brown
4,006 Reputation
2 Guides authored
Metro State, Team 1-3, Carpenter Spring 2016 Member of Metro State, Team 1-3, Carpenter Spring 2016
MSU-CARPENTER-S16S1G3
2 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 9
All Time: 125
