Microsoft Surface Pro 2 LCD Display Replacement
  1. Microsoft Surface Pro 2 LCD Display Replacement, LCD Display: step 1, image 1 of 2 Microsoft Surface Pro 2 LCD Display Replacement, LCD Display: step 1, image 2 of 2
    • To avoid electrical shocks, unplug and turn off your Surface Pro 2 before proceeding.
  2. Microsoft Surface Pro 2 LCD Display Replacement: step 2, image 1 of 1
    • Avoid any skin or eye contact with the heating pad or heating gun because they may cause bodily harm.
    • Using a heating pad or heating gun, heat the edges of the screen to soften the glue. This area extends roughly one inch from the edge of the device.
    • The glue is under the darker border of the device display.
  3. Microsoft Surface Pro 2 LCD Display Replacement: step 3, image 1 of 1
    • Using a plastic opening tool and a suction cup as needed for leverage, gently insert one edge of the opening tool under the corner of the screen.
    • If the tool does not easily slide under the screen, return to heating before proceeding.
    • Slowly work the tool around the entire edge of the screen.
  4. Microsoft Surface Pro 2 LCD Display Replacement: step 4, image 1 of 3 Microsoft Surface Pro 2 LCD Display Replacement: step 4, image 2 of 3 Microsoft Surface Pro 2 LCD Display Replacement: step 4, image 3 of 3
    • Detach the orange cables that connect the screen to the motherboard by pulling on the small tabs. Using the nylon spudger, release these cables.
    • Please note the third small connector in red.
    • Allow the glue to cool before letting it come into contact with any other surface.
    • Follow these steps in reverse order to install the new display.
Mathew B
323 Reputation
2 Guides authored
USF Tampa, Team 6-2, Remmell Fall 2016 Member of USF Tampa, Team 6-2, Remmell Fall 2016
USFT-REMMELL-F16S6G2
4 Members
9 Guides authored
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 73
All Time: 14,487
