Microsoft Surface Book Screen Replacement
  1. Microsoft Surface Book Screen Replacement, Screen: step 1, image 1 of 3 Microsoft Surface Book Screen Replacement, Screen: step 1, image 2 of 3 Microsoft Surface Book Screen Replacement, Screen: step 1, image 3 of 3
    Tool used on this step:
    iSclack
    $24.99
    Buy
    • Turn off your Surface Book and detach the display.
    • Heat and apply an iOpener or use a hair dryer or heat gun to heat the perimeter of the display, in order to soften the glue securing it.
    • Use a suction cup or iSclack or pull up on the edge of the display, and create a slight gap between the display glass and the frame.
    • Insert an opening pick into the gap.
    • The bottom right portion of the screen is where the touch controller attaches to the screen. The ribbon cable is only about a quarter of an inch from the edge of the screen, and is easy to damage.
    • Use only gentle force with the pick, and keep the display very hot (slightly too hot to touch). If you use too much force and/or allow the glue to harden, the glass will crack.
  2. Microsoft Surface Book Screen Replacement: step 2, image 1 of 2 Microsoft Surface Book Screen Replacement: step 2, image 2 of 2
    • Use the pick to slice all the way around the perimeter of the display to separate the glue.
    • Gently raise the display, but don't try to fully detach it until the cables underneath are disconnected.
  3. Microsoft Surface Book Screen Replacement: step 3, image 1 of 3 Microsoft Surface Book Screen Replacement: step 3, image 2 of 3 Microsoft Surface Book Screen Replacement: step 3, image 3 of 3
    • The ribbons are circled. Begin by removing the ribbon on the right (in red). With the curved tweezers, carefully remove the metal bracket to expose the end of the ribbon. Remove ribbon.
  4. Microsoft Surface Book Screen Replacement: step 4, image 1 of 3 Microsoft Surface Book Screen Replacement: step 4, image 2 of 3 Microsoft Surface Book Screen Replacement: step 4, image 3 of 3
    • Next, remove the metal shield covering the other ribbon. Then remove the ribbon.
Wesley Kendrick
2,119 Reputation
2 Guides authored
USF Tampa, Team 1-6, Sullivan Spring 2017 Member of USF Tampa, Team 1-6, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G6
3 Members
14 Guides authored
Past 24 Hours: 4
Past 7 Days: 44
Past 30 Days: 291
All Time: 51,101
