Introduction
In order to replace the Surface 3 tablet's speakers you will have to remove the casing, undo the adhesive that holds the speakers down, and disconnect the speakers from the motherboard.
Warm up an iOpener following the instructions found in the iOpener guide.
Place the warm iOpener on top of the edges of the screen. This heat will weaken the strength of the adhesive between the display and body.
Carefully try to work your way around the device using the picks, reapplications of the heated iOpener, and luck.
You will be working in these areas of the Surface 3 in order to replace the speakers.
Use a pick to get under the speaker part and undo the adhesive that keeps it attached to the back casing.
Use the pick to gently lift on the red and black wire in order to dislodge the connection between the speaker wire and the motherboard.
Simply replace the old speakers by snapping the new speakers into place and connecting the red and black wire to the motherboard.
