Makita XPH01 Forward/Reverse Switch Replacement
  1. Makita XPH01 Forward/Reverse Switch Replacement, Battery: step 1, image 1 of 1
    • Hold the drill upright.
    • Place your finger on the white battery-release button.
  2. Makita XPH01 Forward/Reverse Switch Replacement: step 2, image 1 of 1
    • Press and hold the white release button located on the front of the battery.
  3. Makita XPH01 Forward/Reverse Switch Replacement: step 3, image 1 of 1
    • Slide the battery forward while pressing down on the white battery-release button.
  4. Makita XPH01 Forward/Reverse Switch Replacement, Outer Casing: step 4, image 1 of 2 Makita XPH01 Forward/Reverse Switch Replacement, Outer Casing: step 4, image 2 of 2
    • Hold the drill upright with the back panel facing you.
    • Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
  5. Makita XPH01 Forward/Reverse Switch Replacement: step 5, image 1 of 1
    • Apply slight pressure to the sides of the backplate and pull away from the drill.
  6. Makita XPH01 Forward/Reverse Switch Replacement: step 6, image 1 of 2 Makita XPH01 Forward/Reverse Switch Replacement: step 6, image 2 of 2
    • Unscrew the nine 18 mm screws from the outer casing using a Phillips PH2 screwdriver.
  7. Makita XPH01 Forward/Reverse Switch Replacement: step 7, image 1 of 2 Makita XPH01 Forward/Reverse Switch Replacement: step 7, image 2 of 2
    • Apply slight pressure to the sides of the outer casing and pull away from the drill.
  8. Makita XPH01 Forward/Reverse Switch Replacement, Forward/Reverse Switch: step 8, image 1 of 1
    • Pull the black trigger assembly away from the drill.
  9. Makita XPH01 Forward/Reverse Switch Replacement: step 9, image 1 of 2 Makita XPH01 Forward/Reverse Switch Replacement: step 9, image 2 of 2
    • Grab onto the forward/reverse switch.
    • Gently pull the forward/reverse switch to separate it from the trigger assembly.
Eric Herwatt
984 Reputation
7 Guides authored
Cal Poly, Team 15-4, Livingston Fall 2016 Member of Cal Poly, Team 15-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G4
4 Members
7 Guides authored
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 61
All Time: 5,831
