Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓This guide shows how to remove the main board assembly. This is required before the USB-C board and power supply removal.
Shut down your console and unplug all cables and accessories.
Remove any stands supporting your device and lay it down.
To remove a cover, firmly pull up the front edge to release the clips.
Remove the cover.
Use the cutout on the bottom right corner of the disc drive to lift its right edge and disconnect it.
Remove the disc drive.
Tool used on this step:FixMat$36.95
Use a Phillips screwdriver to remove the 17.1 mm‑long screw securing the expansion slot cover.
Use your fingers to lift the expansion slot cover near the notch by the screw hole and remove it.
Tool used on this step:Tesa 61395 Tape$8.95
Use your fingers to remove the plastic cover hiding the fan cables connector.
Gently pull the fan cables out from under their plastic clip on the frame.
Firmly grip the fan cables white connector head and pull it straight up and out of its socket.
Use a T8 Torx Security screwdriver to remove the four screws securing the fan:
One 31.2 mm‑long screw
Two 21.3 mm‑long screws
One 11.6 mm‑long screw
Use your fingers to grab the fan by its vents, and lift it straight up to remove it.
Insert the fan so its cables are near their connector.
Use a T8 Torx Security screwdriver to remove the two 21.3 mm‑long screws securing the power supply.
Tool used on this step:Tweezers$4.99
A tamper-evident sticker hides one of the right‑side inner shell.
Use tweezers to peel up the sticker until you can access the screw underneath.
Use a T8 Torx Security screwdriver to remove the nine screws securing the right‑side inner shell:
Four 18.9 mm‑long screws
One 21.3 mm‑long screw
Four 31.2 mm‑long screws
Lift the right‑side inner shell straight up and remove it.
Use a T8 Torx Security screwdriver to remove the four screws securing the interconnect cable cover:
One 28.7 mm‑long screw
Three 7.5 mm‑long screws
Use the point of a spudger to push the interconnect cable's metal latch down and away from the connector to unlock it.
Keep the latch in its unlocked position and carefully pull the interconnect cable straight out of its socket.
Insert a spudger under the metal neck of one of the antenna cable's coaxial connectors and lift straight up to disconnect it.
Repeat the process to disconnect the other antenna cable.
Gently lift both antenna cables to separate the tape from the heatsink shield.
Move the antenna cables over the side of your PlayStation so they're out of the way.
Lift the bottom left corner of the main board assembly off its gray plastic post. Keep the assembly lifted for the next step.
Keep the main board assembly raised with one hand.
With your free hand, insert your finger between the assembly and power supply.
Push down on the power supply and lift the assembly to separate them.
Firmly secure the plastic housing with one hand.
With your free hand, grab the upper edge of the main board assembly and lift it out of the plastic housing.
Lower the assembly into its recess so its prongs go into their socket on the power supply and the three cutouts go over their alignment posts.
