Magic Bullet NutriBullet Base Replacement
  1. Magic Bullet NutriBullet Base Replacement, Base: step 1, image 1 of 1
    • Unplug the device from the wall and turn the powerbase upside down.
  2. Magic Bullet NutriBullet Base Replacement: step 2, image 1 of 2 Magic Bullet NutriBullet Base Replacement: step 2, image 2 of 2
    • Unscrew the four 10mm screws located on the bottom of the powerbase using the Phillips Head #2 Screwdriver.
  3. Magic Bullet NutriBullet Base Replacement: step 3, image 1 of 1
    • Once the screws are removed, use slight tension to pull the plastic base up.
    • Make sure the cord does not get caught or frayed by the fan, which is located in the center of the power base.
Angela Wong
1,099 Reputation
3 Guides authored
Cal Poly, Team 19-8, Maness Winter 2015 Member of Cal Poly, Team 19-8, Maness Winter 2015
CPSU-MANESS-W15S19G8
4 Members
10 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 47
All Time: 9,560
