Macintosh Powerbook 5300cs RAM Replacement
  1. Macintosh Powerbook 5300cs RAM Replacement, Battery: step 1, image 1 of 1
    • The battery compartment is located in the front-right side of the laptop.
  2. Macintosh Powerbook 5300cs RAM Replacement: step 2, image 1 of 1
    • To insert the battery, gently slide it into the compartment until it clicks in place.
    • To remove, slide the button highlighted in the red rectangle to the right to release the battery and slide it from the compartment.
  3. Macintosh Powerbook 5300cs RAM Replacement, Keyboard: step 3, image 1 of 1
    • With the laptop upside down and with the battery removed, use a Torx #9 screw driver to remove the three .84 in. screws shown.
  4. Macintosh Powerbook 5300cs RAM Replacement: step 4, image 1 of 2 Macintosh Powerbook 5300cs RAM Replacement: step 4, image 2 of 2
    • Carefully pull up on the front of the keyboard to pop it out from the case.
    • Then slide the back out so the keyboard becomes nearly free.
  5. Macintosh Powerbook 5300cs RAM Replacement: step 5, image 1 of 3 Macintosh Powerbook 5300cs RAM Replacement: step 5, image 2 of 3 Macintosh Powerbook 5300cs RAM Replacement: step 5, image 3 of 3
    • Disconnect the ribbon that is connecting the keyboard to the rest of the computer.
    • Pull the keyboard out and repair or replace as needed.
  6. Macintosh Powerbook 5300cs RAM Replacement, RAM: step 6, image 1 of 3 Macintosh Powerbook 5300cs RAM Replacement, RAM: step 6, image 2 of 3 Macintosh Powerbook 5300cs RAM Replacement, RAM: step 6, image 3 of 3
    • Remove the RAM board located underneath the keyboard by carefully popping it out from its connection. Reinstall or replace as necessary.
Ronan
63 Reputation
4 Guides authored
Cal Poly, Team 6-1, Regan Fall 2011 Member of Cal Poly, Team 6-1, Regan Fall 2011
CPSU-REGAN-F11S6G1
4 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 929
