Introduction
Accessing the RAM in this computer is straightforward and requires minimal disassembly.
Slightly lift the lower case near the vent opening.
Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
