Introduction
Don't pay Apple to replace your worn out battery. Do it yourself!
Slightly lift the lower case near the vent opening.
Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Use the tip of a spudger to carefully peel back the finger of the warning label to reveal a hidden Tri-point screw.
Remove the 5 mm Tri-point screw securing the battery to the upper case.
Use the battery's plastic pull tab to lift and remove the battery from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
