MacBook Unibody Model A1342 Battery Replacement
  1. MacBook Unibody Model A1342 Battery Replacement, Lower Case: step 1, image 1 of 1
    • Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
  2. MacBook Unibody Model A1342 Battery Replacement: step 2, image 1 of 3 MacBook Unibody Model A1342 Battery Replacement: step 2, image 2 of 3 MacBook Unibody Model A1342 Battery Replacement: step 2, image 3 of 3
    • The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
    • Slightly lift the lower case near the vent opening.
    • Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
    • The location of these three clips is shown in the third picture.
  3. MacBook Unibody Model A1342 Battery Replacement, Battery: step 3, image 1 of 1
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
    • It may be easier to use your fingernails to lift up on both sides of the connector.
  4. MacBook Unibody Model A1342 Battery Replacement: step 4, image 1 of 1
    • Remove two 5 mm Tri-point screws securing the battery to the upper case.
  5. MacBook Unibody Model A1342 Battery Replacement: step 5, image 1 of 1
    • Use the tip of a spudger to carefully peel back the finger of the warning label to reveal a hidden Tri-point screw.
    • Remove the 5 mm Tri-point screw securing the battery to the upper case.
  6. MacBook Unibody Model A1342 Battery Replacement: step 6, image 1 of 1
    • Remove three 3.1 mm Phillips screws securing the battery near the edge of the upper case.
    • When reinstalling the battery, be sure to install these three screws before proceeding to fasten the Tri-point screws.
  7. MacBook Unibody Model A1342 Battery Replacement: step 7, image 1 of 1
    • Use the battery's plastic pull tab to lift and remove the battery from the upper case.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Past 24 Hours: 6
Past 7 Days: 92
Past 30 Days: 408
All Time: 406,298
