MacBook Pro 17" Unibody Battery Replacement
  1. MacBook Pro 17" Unibody Battery Replacement, Lower Case: step 1, image 1 of 1
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 17" Unibody Battery Replacement: step 2, image 1 of 2 MacBook Pro 17" Unibody Battery Replacement: step 2, image 2 of 2
    • Wedge your fingers between the lower case and the vent, and lift upward to release the two clips holding the lower case to the upper case.
    • During reassembly, carefully align the lower case and then press it firmly until both clips engage.
    • Remove the lower case.
  3. MacBook Pro 17" Unibody Battery Replacement, Battery: step 3, image 1 of 2 MacBook Pro 17" Unibody Battery Replacement, Battery: step 3, image 2 of 2
    • Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits.
    • Grab the plastic tab attached to the battery connector and pull it toward the front edge of the device.
    • Pull the tab parallel to the face of the logic board.
  4. MacBook Pro 17" Unibody Battery Replacement: step 4, image 1 of 1
    • Remove the three 6.5 mm Tri-point screws securing the battery to the upper case.
  5. MacBook Pro 17" Unibody Battery Replacement: step 5, image 1 of 2 MacBook Pro 17" Unibody Battery Replacement: step 5, image 2 of 2
    • Use a plastic opening tool or another soft thin-edged tool to carefully lift up a corner of the "Warning: Do not remove the battery" sticker off the right speaker/subwoofer enclosure.
    • Peel the sticker off the right speaker/subwoofer enclosure.
    • It is not necessary to completely peel the sticker off the battery.
  6. MacBook Pro 17" Unibody Battery Replacement: step 6, image 1 of 1
    • Lift the battery by its attached pull tab and remove it from the upper case.
Past 24 Hours: 4
Past 7 Days: 88
Past 30 Days: 396
All Time: 325,449
