Introduction
使用本指南来更换MacBook Pro电池。 更换电池需要三点螺丝刀。
要重新组装您的设备,请按照本指南的相反顺序进行操作。
205 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
33 Comments
Maybe good to know: as this type of MacBook Pro is already ageing, mine showed some bulging in the battery. As I don't use my MacBook Pro anymore as a real laptop, for me, it doesn't matter anymore to replace the battery. But for safety reasons, I removed the bulging battery, and the MacBook Pro is still running fine!
Hello, i've tryed to do it but without the battry my macbook didn't turned on... do you have any tip? Did you have to configure anything inside? My mac is a Macbook pro 17'' 6,1 mid 2010
@kirapereira, it should work. I took my bulging battery out and made no configuration changes. Just make sure you keep the MBP plugged into a working electrical outlet at all times and keep it plugged in while you are using it. If the magsafe connector gets dislodged for any reason the computer will shutdown immediately, no warnings or questions asked.
I just changed my A1297 model Late 2011 MacBook Pro 17" battery using a NewerTech battery kit (includes the two tools you need) that I sourced off OWC (OtherWorldComputing aka MacSales website) and using their installation video (while checking it against install guides on EverythingMac and the iFixit websites) The replacement went without a hitch and the battery is charging now The only thing I had to do was reset the clock after boot up I will report problems here, if any But if not, then Finito!
