Introduction
Upgrade your hard drive for more storage space! This guide will also show you how to replace the hard drive bracket.
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
Remove the lower case and set it aside.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
Lift the hard drive by its pull tab and pull it out of the chassis, minding the cable attaching it to the computer.
Remove two T6 Torx screws from each side of the hard drive (four screws total).
If desired, peel the pull tab off your old hard drive and transfer it to the side of your new drive.
