Installing MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board
  1. Installing MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board, Lower Case: step 1, image 1 of 1
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
  2. Installing MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board: step 2, image 1 of 1
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. Installing MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board, AirPort/Bluetooth Cable: step 3, image 1 of 2 Installing MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board, AirPort/Bluetooth Cable: step 3, image 2 of 2
    • Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the logic board.
    • Carefully peel the AirPort/Bluetooth ribbon cable off the top of the black plastic AirPort/Bluetooth housing.
  4. Installing MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board: step 4, image 1 of 1
    • Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off its socket on the AirPort/Bluetooth board.
  5. Installing MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board, AirPort/Bluetooth Board: step 5, image 1 of 1
    • Disconnect the camera cable by pulling its connector away from the socket on the logic board.
    • Pull the connector toward the optical drive opening.
  6. Installing MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board: step 6, image 1 of 1
    • Pry the AirPort and Bluetooth antenna connectors (3 total) up off the AirPort/Bluetooth board.
  7. Installing MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board: step 7, image 1 of 2 Installing MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board: step 7, image 2 of 2
    • De-route all three antenna cables from their channels in the black plastic AirPort/Bluetooth housing.
  8. Installing MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board: step 8, image 1 of 2 Installing MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board: step 8, image 2 of 2
    • Remove the two Phillips screws securing the AirPort/Bluetooth board housing to the upper case.
    • Carefully remove the AirPort/Bluetooth assembly from the lower case.
  9. Installing MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board: step 9, image 1 of 1
    • Remove the two Phillips screws securing the AirPort/Bluetooth board to the AirPort/Bluetooth board housing.
  10. Installing MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board: step 10, image 1 of 1
    • Remove the AirPort/Bluetooth board from its black plastic housing.
  11. Installing MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board: step 11, image 1 of 2 Installing MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board: step 11, image 2 of 2
    • Before securing the AirPort/Bluetooth bracket to the upper case, be sure the small plastic tab on its left edge is inserted into the small void cut into the black plastic optical drive opening.
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 82
All Time: 71,060
