MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board Replacement
  1. MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board Replacement, Lower Case: step 1, image 1 of 1
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
  2. MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board Replacement: step 2, image 1 of 1
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board Replacement, AirPort/Bluetooth Cable: step 3, image 1 of 2 MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board Replacement, AirPort/Bluetooth Cable: step 3, image 2 of 2
    • Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the logic board.
    • Carefully peel the AirPort/Bluetooth ribbon cable off the top of the black plastic AirPort/Bluetooth housing.
  4. MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board Replacement: step 4, image 1 of 1
    • Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off its socket on the AirPort/Bluetooth board.
  5. MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board Replacement, AirPort/Bluetooth Board: step 5, image 1 of 1
    • Disconnect the camera cable by pulling its connector away from the socket on the logic board.
    • Pull the connector toward the optical drive opening.
  6. MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board Replacement: step 6, image 1 of 1
    • Pry the AirPort and Bluetooth antenna connectors (3 total) up off the AirPort/Bluetooth board.
  7. MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board Replacement: step 7, image 1 of 2 MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board Replacement: step 7, image 2 of 2
    • De-route all three antenna cables from their channels in the black plastic AirPort/Bluetooth housing.
  8. MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board Replacement: step 8, image 1 of 2 MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board Replacement: step 8, image 2 of 2
    • Remove the two Phillips screws securing the AirPort/Bluetooth board housing to the upper case.
    • Carefully remove the AirPort/Bluetooth assembly from the lower case.
  9. MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board Replacement: step 9, image 1 of 1
    • Remove the two Phillips screws securing the AirPort/Bluetooth board to the AirPort/Bluetooth board housing.
  10. MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board Replacement: step 10, image 1 of 1
    • Remove the AirPort/Bluetooth board from its black plastic housing.
  11. MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board Replacement: step 11, image 1 of 2 MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board Replacement: step 11, image 2 of 2
    • Before securing the AirPort/Bluetooth bracket to the upper case, be sure the small plastic tab on its left edge is inserted into the small void cut into the black plastic optical drive opening.
31 other people completed this guide.
5 Comments
I didn't even have to replace my daughterboard -- I ordered a used one, but simply "reseating" (removing and attaching it again) the ribbon cable to the daughter board fixed my problem that the WiFi and Bluetooth card was invisible to the OS.
Thanks anyway for these great instructions! Without them I hadn't even thought about that the WiFi functionality was on a daughterboard... I thought other than in most "Windows laptops" that functionality was integrated into the main board.
Ralf Bergs - Reply
Excellent guide! The whole thing took me about 30 minutes and as soon as I turned on my mac again the WiFi worked perfectly.
Yannick Streit - Reply
I replaced both the card and the ribbon cable. Still get the message that there is no WiFi device installed. 15" MBP, mid-2010. The Bluetooth and Ethernet still work. But it is very inconvenient not having WiFi. Any thoughts on what else to try would be appreciated.
Raymond Steinbart
rsteinbart - Reply
Excellentguide as usual, but not sure the anntena cables should have be replaced in their housings before the Airport/ Bluetooth bracket was secured. Was there a reason I missed.
Peter Mayo - Reply
Is it possible to upgrade? Is there any “successor” known for Bluetooth 4.0 ?
Thanks
Markus Kappeler - Reply
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 84
All Time: 71,045
