MacBook Pro 15" Touch Bar 2018 Cooling optimization
  1. MacBook Pro 15" Touch Bar 2018 Cooling optimization, Disable Auto Boot: step 1, image 1 of 3 MacBook Pro 15" Touch Bar 2018 Cooling optimization, Disable Auto Boot: step 1, image 2 of 3 MacBook Pro 15" Touch Bar 2018 Cooling optimization, Disable Auto Boot: step 1, image 3 of 3
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled āŽ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
    • sudo nvram AutoBoot=%03
  2. MacBook Pro 15" Touch Bar 2018 Cooling optimization, Lower Case: step 2, image 1 of 2 MacBook Pro 15" Touch Bar 2018 Cooling optimization, Lower Case: step 2, image 2 of 2
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Completely power off and unplug your MacBook Pro before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove six screws securing the lower case, of the following lengths:
    • Four 4.7 mm screws
    • Two 6.6 mm screws
    • Note how the screws come out at a slight angleā€”you must reinstall them the same way.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  3. MacBook Pro 15" Touch Bar 2018 Cooling optimization: step 3, image 1 of 2 MacBook Pro 15" Touch Bar 2018 Cooling optimization: step 3, image 2 of 2
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle just enough to open a small gap under the lower case.
  4. MacBook Pro 15" Touch Bar 2018 Cooling optimization: step 4, image 1 of 3 MacBook Pro 15" Touch Bar 2018 Cooling optimization: step 4, image 2 of 3 MacBook Pro 15" Touch Bar 2018 Cooling optimization: step 4, image 3 of 3
    • Slide the corner of an opening pick into the gap you just created underneath the lower case.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
  5. MacBook Pro 15" Touch Bar 2018 Cooling optimization: step 5, image 1 of 3 MacBook Pro 15" Touch Bar 2018 Cooling optimization: step 5, image 2 of 3 MacBook Pro 15" Touch Bar 2018 Cooling optimization: step 5, image 3 of 3
    • Repeat the previous step on the other side, using an opening pick to to release the second clip.
  6. MacBook Pro 15" Touch Bar 2018 Cooling optimization: step 6, image 1 of 1
    • Lift the front edge of the lower case (the side opposite the display hinge) enough to slide your fingertips underneath and get a good grip on it.
    • Two additional hidden clips near the middle of the cover should pop free at this point, if they haven't already.
    • Don't lift more than an inch or so, and don't try to remove the lower case yet.
  7. MacBook Pro 15" Touch Bar 2018 Cooling optimization: step 7, image 1 of 3 MacBook Pro 15" Touch Bar 2018 Cooling optimization: step 7, image 2 of 3 MacBook Pro 15" Touch Bar 2018 Cooling optimization: step 7, image 3 of 3
    • Pull firmly to slide the lower case towards the front edge of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • Pull first at one corner, then the other.
    • Pull to the sideā€”not up.
    • This may require a lot of force.
  8. MacBook Pro 15" Touch Bar 2018 Cooling optimization: step 8, image 1 of 3 MacBook Pro 15" Touch Bar 2018 Cooling optimization: step 8, image 2 of 3 MacBook Pro 15" Touch Bar 2018 Cooling optimization: step 8, image 3 of 3
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
  9. MacBook Pro 15" Touch Bar 2018 Cooling optimization, Cooling optimization: step 9, image 1 of 1
    • Cut the thermal pad to fit the CPU and GPU.
    • Dimensions: 50 mm x 50m x 0.8 - 1 mm
    • Remove the first protective film from the pad and carefully place it on the two visible areas (CPU and GPU) and press it down lightly.
    • After the pad is pressed down and fits snugly, remove the second side of the protective film.
Work through the steps in reverse order to reassemble your device.
21 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Pascal Keinath
773 Reputation
1 Guide authored
10 Comments
Thanks for the instruction on how to make this MBP run cooler
macisgr8 - Reply
It would be useful to mention the thermal pad and thermal paste at the beginning.
Please provide specifications for the thermal pad and thermal paste, or suggestions for each.
Paul Jackson - Reply
0,5 mm thermalpad was to thin for me, I used it in two layers, 50x50mm was enough for that
Some One - Reply
This guide was also useful when just wanting to take everything apart to clean the fans.
Brian Franklin - Reply
Amazing! Thank you for this safe 'n easy guide. I mean that is a difference... Twitter post
Daniel Scharkov - Reply
Past 24 Hours: 11
Past 7 Days: 121
Past 30 Days: 666
All Time: 24,020
