MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement, AirPort/Camera Cables: step 1, image 1 of 3 MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement, AirPort/Camera Cables: step 1, image 2 of 3 MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement, AirPort/Camera Cables: step 1, image 3 of 3
    • Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board, and bend them up and out of the way.
    • The cable connection points are fragile. Be careful to lift only on the connector, and not on the socket or cable.
    • To reconnect, align the connector carefully into position over the socket, and press it down firmly with the flat of your spudger.
  2. MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement: step 2, image 1 of 2 MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement: step 2, image 2 of 2
    • Peel the right rubber cover up off the fan and fold it out of the way.
  3. MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement: step 3, image 1 of 2 MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement: step 3, image 2 of 2
    • Use the tip of a spudger to push the camera cable connector out of its socket on the logic board.
    • Be sure to push parallel to the board, pushing first on one side, then the other to "walk" the connector out of its socket.
  4. MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement: step 4, image 1 of 3 MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement: step 4, image 2 of 3 MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement: step 4, image 3 of 3
    • Use your fingers to pull the AirPort/Camera cables up off the fan.
    • The cables are adhered to the fan, so peel them up carefully to avoid damaging them.
    • Carefully de-route the cables from the plastic cable guide.
    • On reassembly, there should be enough adhesive still on these cables to stick them back down to the fan.
Andrew Optimus Goldheart
503,061 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,267 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 13
All Time: 373
