MacBook Pro 15" Retina Display Mid 2015 AirPort Board Replacement
  1. MacBook Pro 15" Retina Display Mid 2015 AirPort Board Replacement, Lower Case: step 1, image 1 of 1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.1 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Mid 2015 AirPort Board Replacement: step 2, image 1 of 2 MacBook Pro 15" Retina Display Mid 2015 AirPort Board Replacement: step 2, image 2 of 2
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
  3. MacBook Pro 15" Retina Display Mid 2015 AirPort Board Replacement: step 3, image 1 of 3 MacBook Pro 15" Retina Display Mid 2015 AirPort Board Replacement: step 3, image 2 of 3 MacBook Pro 15" Retina Display Mid 2015 AirPort Board Replacement: step 3, image 3 of 3
    • The lower case has two plastic pegs (red) that fit into plastic clips in the upper case (orange).
    • During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips.
  4. MacBook Pro 15" Retina Display Mid 2015 AirPort Board Replacement, Battery Connector: step 4, image 1 of 1
    • Peel back the sticker covering the battery connector.
  5. MacBook Pro 15" Retina Display Mid 2015 AirPort Board Replacement: step 5, image 1 of 3 MacBook Pro 15" Retina Display Mid 2015 AirPort Board Replacement: step 5, image 2 of 3 MacBook Pro 15" Retina Display Mid 2015 AirPort Board Replacement: step 5, image 3 of 3
    • Gently lift each side of the battery connector to pry the connector out of its socket on the logic board.
    • Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  6. MacBook Pro 15" Retina Display Mid 2015 AirPort Board Replacement, AirPort Board: step 6, image 1 of 3 MacBook Pro 15" Retina Display Mid 2015 AirPort Board Replacement, AirPort Board: step 6, image 2 of 3 MacBook Pro 15" Retina Display Mid 2015 AirPort Board Replacement, AirPort Board: step 6, image 3 of 3
    • Disconnect the three airport Antenna cable connectors from their sockets on the AirPort board and bend them up and out of the way.
    • Be careful to pry only against each connector, and not its cable or socket.
  7. MacBook Pro 15" Retina Display Mid 2015 AirPort Board Replacement: step 7, image 1 of 1
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort board.
  8. MacBook Pro 15" Retina Display Mid 2015 AirPort Board Replacement: step 8, image 1 of 3 MacBook Pro 15" Retina Display Mid 2015 AirPort Board Replacement: step 8, image 2 of 3 MacBook Pro 15" Retina Display Mid 2015 AirPort Board Replacement: step 8, image 3 of 3
    • Lift the end of the AirPort board up enough to pass over the heat sink directly behind it.
    • Do not lift the AirPort board too high, or you could damage the contacts or socket.
    • Pull the AirPort board straight out of its socket on the logic board.
    • There is a slightly adhesive thermal pad beneath the AirPort board. Be sure to reapply this when reinstalling the board, or transfer it to your replacement board.
Andrew Optimus Goldheart
503,280 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
Past 24 Hours: 12
Past 7 Days: 47
Past 30 Days: 203
All Time: 31,082
