MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement
  1. MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement, Remove the lower case screws: step 1, image 1 of 1
    • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Seven 3 mm Phillips screws.
    Compare the short screws carefully before reinstalling them. The shouldered screws go in the holes on the front edge.
    David Kilbridge - Reply
    Before I started removing any screws I took a piece of paper and drew the bottom of the laptop and put a piece of double-sided tape in the spot where each screw goes. That way when I took out the screws, I could put them on the tape so I knew exactly which screw went in which spot. I did the same thing for dismantling the inside on another sheet of paper, then a third sheet for the screen after getting the front glass off.
    mastover - Reply
    I use a similar technique: I print out the iFixit manual for the job, and Scotch-tape down the screws/brackets/cables I remove at each step next to the component descriptions. That way, when I'm reassembling, the bits are taped right next to the photo of where they came from.
    adlerpe -
    That's exactly what I do for all my repairs! It's the best way to keep track of all of the parts ' original location and to make sure that you don't miss any parts during reassembly.
    joyitsjennie -
    Great idea and one I use often
    Thomas Overstreet -
    Excellent idea! Thanks for sharing it here.
    Laura Sharkey -
    I used a 00 that fit but the screws were very tight so I used a tiny paintbrush with some wd40 on it and put it around the edges of the screws. Worked like a charm
    valentinedhdh - Reply
    I use a magnetic mat and place the screws in order on that :)
    Cary B - Reply
  2. MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement, Lift the lower case away: step 2, image 1 of 1
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
    In the introduction you should link fixers to this excellent doc: https://www.ifixit.com/Misc/HD_Software_...
    It is really critical, super easy, and free(!) to clone your existing drive onto the new one you will install. I ran into one error, but SuperDuper! support replied immediately on how to fix it...Thanks ifixit and SuperDuper! (I ponied up the $28 for the software anyway, I was so impressed!)
    Mike - Reply
    Long story short: I drank the AppleKoolAid back in 1984 and have always left the guts of my machines up to Apple - until recently when I needed to swap the SATAs from my original MacDaddy (2009 13" MBPro that I killed in 2018 - coffee + blackout = OOOOPS) into a pristine 2009 MBPro from a Goodwill in North Carolina through eBay. I need the files from iCal and MacMail that can't be opened in my newer machines.
    Well . . . I ain't never done nuttin' like that, before!
    Enter Luke Miani on YouTube. He raves about you guys! So, I watched everything I could, read your site, bought the right tools and at the ripe old age of 72, I sat down, this morning and did the work. Now my original MacDaddy lives in MacDaddy2.0.
    Am I allowed to cry?
    Seriously, I can't thank you enough for your bitchen site and killer tools. I wish I'd'a been turned on to this shizzle 30+ years ago.
    IFIXIT - IDIGIT!
    kath myers - Reply
    HAHAHAHAHAHAHAHAHAHA.
    That was a brilliant read.
    Yes, I came across ifixit a few years ago. Totally helped me out on several occasions.
    Glad your Mac repair journey worked out.
    Cary B -
  3. MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement, Battery: step 3, image 1 of 1
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
    Quote from gansodesoya:
    why is step 3 necessary?
    Just to disconnect any power source to avoid damages by short-circuits.
    MrKane - Reply
    How do you get that battery connector back on? Do you just press it in back in place after you're done?
    Horace Chung - Reply
    yes. I usually plug it in before I screw it down so I can lift the battery a bit and have enough slack to be able to go straight down on the connector, otherwise it comes in on a bit of an angle, which can't be good (though not necessarily bad).
    maccentric -
    This step almost finished me, and I did extensive damage to the battery plug. Fortunately, I later replaced the battery, and the replacement came with a new plug! :) Newbies need to know - 1. The battery plug is like a thin lip on a thicker lip, so you need to pry BETWEEN 2 thin lips to get it off, else you are trying to yank out the socket. 2. Mine was initially VERY tight, and trying to get it out broke the plastic on all sides of plug, even though I was as careful as possible. Luckily, this didn't hurt functionality and I later replaced the battery. AFTER disconnecting once, it was never so tight again,
    Jeff Diamond - Reply
  4. MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement, Optical Drive: step 4, image 1 of 1
    • For precautionary purposes, we advise that you disconnect the subwoofer connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
    • Remove the soft padding that may be on top and gently pull the connector up out of its socket on the logic board.
    It is not necessary to remove the camera cable connector (step 5) or the camera cable connector (step 10). Simply push the camera cable gently aside to remove one of the three screws securing the optical drive (step 11). Gently wiggle the optical drive from under the camera cable connector and go to step 12. Less chance of ruining your motherboard!
    tomhart - Reply
    Absolutely. Leave it alone, you don’t need to run the risks of removing this cable, I did the replacement fine without it
    Steven Taylor -
    It does indeed come out of the connector, but the picture makes it hard to see how; the connector it goes into sits on top of the board—however, I, too, ripped mine off the board trying to remove it; I only got it out of the clip after I tore it off. SIMPLY DONT; it's unnecessary. I plan to solder it back if one of my Robotics club friends lets me borrow a soldering iron.
    Rachel - Reply
    Alors je déconseille très fortement de toucher ce connecteur, il est extrêmement fragile. De plus, cela n’a pas d’incidence sur la suite des opérations
    Laskoni - Reply
    The author needs to go back through this guide and correct lots of order mistakes. The fan was removed in steps 3-5 yet it’s still being shown installed in steps 19-22.
    plink53 - Reply
    The 4-pin push connector for the sub-woofer is near impossible to reconnect
    It mates with a female connector that sits on top of 4 tiny solder points (it's held on by a spot of glue, I believe), and when applying ANY pressure to connect, the side clip(s) will snap off. Then the connector itself will become unglued. It would be simple enough to connect the 2 parts, then place a drop of glue on the logic board after positioning it above the solder points, but the female connector broke apart in my hand. So now screwed, with no way to connect sub/ R speaker without installing another logic board. Fan connector looks to be exactly the same
    Peter Watkins - Reply
  5. MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement: step 5, image 1 of 1
    • It will be necessary to slide the small clear plastic cable retainer (boxed in red) glued to the logic board out of the way before disconnecting the camera cable. Be careful not to break any components off the board as you slide it away from the camera cable connector.
    • Pull the camera cable connector toward the optical drive to disconnect it from the logic board.
    • This socket is metal and can be easily bent. Be sure to align the connector with its socket on the logic board before mating the two pieces.
    I just completed this replacement and there is no need to do this step, you can work around this cable pretty easily. Obviously you need to be careful "dancing" around it. But it's perfectly feasible and you don't risk to break stuff disconnecting it.
    Massimo C - Reply
  6. MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement: step 6, image 1 of 1
    • Use the flat end of a spudger to pry the optical drive connector straight up off the logic board.
  7. MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement: step 7, image 1 of 1
    • Use the flat end of a spudger to pry the hard drive connector straight up off the logic board.
  8. MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement: step 8, image 1 of 1
    • Remove the following screws securing the subwoofer to the upper case:
    • One 3.8 mm Phillips screw
    • One 5 mm Phillips screw
    On my computer, the 3.8 mm screw was near the midpoint of the subwoofer (left-to-right in the photo) and near the bottom. The 5 mm screw was top right of the subwoofer.
    BobG - Reply
  9. MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement: step 9, image 1 of 2 MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement: step 9, image 2 of 2
    • The subwoofer is still connected to the right speaker, so don't completely remove it just yet.
    • Lift the subwoofer off the optical drive, and set it above the computer.
  10. MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement: step 10, image 1 of 2 MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement: step 10, image 2 of 2
    • Remove the two 10 mm Phillips screws securing the camera cable bracket to the upper case.
    • The leftmost screw may remain captive in the camera cable.
    • Lift the camera cable bracket out of the upper case.
  11. MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement: step 11, image 1 of 2 MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement: step 11, image 2 of 2
    • Remove the three 2.5 mm Phillips screws securing the optical drive to the upper case.
    • Lift the optical drive from its right edge and pull it out of the computer.
    Install 2 outside screws first and then single inside screw to allow wiggle room to get outside screws in. Do not tighten screws until all are started.
    JASON CULP - Reply
  12. MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement, Subwoofer & Right Speaker: step 12, image 1 of 1
    • Peel back the small piece of black tape covering the right speaker cable.
    • Be careful, as the power button ribbon cable is directly under this piece of tape.
  13. MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement: step 13, image 1 of 1
    • Use the tip of a spudger to pry the right speaker up off the adhesive securing it to the upper case.
    I recommend you to use for this step an opening tool instead the spudger. The jimmy is a good option
    Toni - Reply
    The new speakers don’t come with adhesive, so some double sided tape is handy. Also, the right speaker cable can be rather long, so some tape is useful to carefully loop it out the way.
    Steven Taylor - Reply
  14. MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement: step 14, image 1 of 1
    • Lift the subwoofer and right speaker assembly out of the upper case.
52 other people completed this guide.
3 Comments
Oh yeaAAHHH! Right speaker & subwoofer fixed. Thank you!
eepmon - Reply
The replacement subwoofer connector (step 4, which disconnection is required, not optional)was just a bit shorter, and just barely fit, so it was ‘iffy’ whether I’d get it to stay, but it did. Yea! No more sound distortion!!! Such an easy thing to fix!
wyrra - Reply
Hello, I've just brought a MacBook Pro 8,1 to life with an SSD. It works great but unfortunately no sound. There is no output listed in sound window. I tried cmd+opt+P+R without success. Would replacing the speaker assembly solve the problem or is this a hardware problem? Thanx
PS- I also restarted cord...something in processes that didn't work either.
edwood - Reply
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 142
All Time: 61,468
