Introduction
Use this guide to replace the left speaker.
When operating normally, during most of the guide it will be on the right, as your laptop will be upside down.
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Wedge your fingers between the upper case and the lower case.
Gently pull the lower case away from the upper case to remove it.
Agreed. A decent amount of force is required here.
To reattach bottom case I found it helpful to line fingers up with clips under case should snap easily
Easy snapped off for me
Popped off of the bottom case for me. My batteries were dangerously inflated
What is the black vinyl-y sticker on the inside of the case (some sort of shield?). I was forced to slightly puncture it in order to replace the feet on my laptop. Thanks in advance.
When I got the back off, I found this piece loose, any idea what it is? about 9mm long frosted plastic
I took my pointer and thumb (which are luckily long enough) to feel where the studs are on the back panel, and then as I put the back panel back on, I pushed in the spot I had marked with my fingers to ensure I was applying pressure only on this part.
Can you make a youtube video showing the steps? I am not sure how to proceed with this step. I want to see it done.
Thanks.
My new battery kit included a replacement for this part, so, no need to save the old one.
The aux in my mac works 1 out of 10 times , Is this relevant to me in order to solve the proplem ? I cant see aux input on the io board ?
A plastic foam cover also covers plug and socket and the whole battery. It is easy to remove it from the right side to the trackpad wire that the battery plug is free like shown in the picture. I kept it to use it again later.
Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
I have a friends MacBook Pro that has some water damage that caused the MacBook not to be able to use battery power, but still work when plugged into A/C. Upon further inspection I can see visible corrosion on a few of the 9 cables going from the battery connector to that small circuit board. Is it possible to just replace that circuit board?
I have the some problem. I was thinking to replace the whole battery but I am not it will solve the problem. Any suggestions?
Sometimes it can be enough to just clean the contacts without having to replace the entire board. Dosent work for complicated IC's like plcc type, where corrosion is underneath the chip. Here you will have to reheat and reapply the IC.
Hi,have you find the solution for your battery? I also have same problem, run with plugs but it battery not supporting… as soon the plug of it goes off
Have either of you replaced the battery and/or circuit board to fix the MacBooks with the water damage ? I have the same problem with the MacBook working fine when connected to power but dying immediately when the power cord is removed.
Hi, Steve. I had the same problem: Macbook Pro 15 retina with coffee damage. And it worked fine when connected to power. I made it working after replacing the whole battery. It seems that circuit connected to the battery becomes disabled to prevent short circuit.
When placing the battery connector back into the socket on the logic board, check that every part of connector is pressed down. You should hear a soft click when it's back in place.
Thanks for the comment. My MBP isn’t powering on after I walked through these steps, and I assume it is because the battery connector isn’t fully connected. (I can’t check yet since I borrowed the pentalobe screwdriver)
+1
I thought I made sure it was connected but when running the computer it only detected the battery but couldn’t power it. I had to run with power adapter. Also it didn’t charge. I guess some pins were connected but not all. To verify that all were connected I removed the plastic cover, placed it carefully completely flat, and then reattached the plastic cover. After that it worked!
If I only want to replace the trackpad cable, then which steps should I skip? This step seems unnecessary
This step is not unnecessary because you need to remove the battery before you can replace the trackpad
I replaced both my L and R speakers on my MBP mid-2014 13” withOUT doing this step.
I did the same thing, probably unnecessary to disconnect the battery. I’m not a technician however.
I have verified I have this battery, and I have a mid-2014 macbook retina. And I swear i do not see this battery connector. I didn’t take the cover off, per other comments that said it was an unnecessary risk. What the heck? will I not see the battery cable without taking of that cover?
ooops nevermind..I see it now! tks . But..there is SO much gunk/dust under there (old, hand me down, used by my teen daughter while eating in bed no doubt!) . Should I attempt to clean? Beyond just blowing on it? Is compressed air safe? Or should I just leave it be? Assuming I don’t break it while replacing this battery I’d like not to break it otherwise! tks
Lift from the long, flat side, not the shorter side. In this picture, you should lift from the NORTH part of the connector, not the WEST side like they are doing. This is because you can spread the pressure from lifting the connector across more area, as compared to the side. I accidentally broke off part of my battery connector lifting it up the way shown, but was able to do it the way I described without problem. Make sure to lift from the wide part so you don’t have my same trouble!
If you miss or let this step for later like I did, the power left in the battery even though the computer is completely shut down, will screw up the I/O board cable like I did. I noticed this after I put all the pieces back, turn the computer on and surprise, no wifi hardware is detected. -.-
Not sure I understand: did leaving the battery plugged in permanently broke the I/O board (or anything else)?
Adrien -
That’s a great idea!
I agree that inserting a small paper above between the socket and the connector was useful. I used post-it-note, but kept the adhesive away from the socket.
Insert the tip of a spudger under the left speaker cable near the connector and lift it up out of its socket on the logic board.
Same as my comment on Step 11: This step was not necessary for me to remove the battery. Perhaps it's a safety precaution? Regardless, I skipped the speaker cable removal (Steps 11, 12) and didn't have any problems replacing the battery. ( FYI - I used a heat path method, vs the solvent).
Yes, no need to unplug the speakers cable. I used the solent, just put speakers on the motherboard.
I picked up my steps back here when replacing both my L and R speakers on my MBP mid-2014 13”. I used the flat part of the spudger and gently, carefully applied a fulcrum upward pressure to the base of the speaker connector to help pop it off.
I, too, found it unnecessary to unplug this speaker. It was easy, and not stressful to the speaker cable, to fold the speaker upwards and rest it on the motherboard.
When removing the left speaker as shown in the image in the photo, the left-most fixing part (protrusion) is broken. Will there be any problems using it?
Remove the following screws securing the left speaker to the upper case:
One 5.7 mm T5 Torx screw
One 6.5 mm T5 Torx screw
One 3.8 mm T5 Torx screw
Same note as above: Important to keep track here of which screw is which, for reassembly. The longest screw belongs in the middle socket. The shortest goes in the socket at the bottom of the picture.
Where can I get these 3 sizes of t5 torx screw drivers?
Greg, the T5 Torx screw driver is one size. The different sizes listed above are the *lengths* of the screws, not the diameter of the screw head. Hope that helps.
My Torx screws are so locked i can not take it out. The Torx 5 screw driver slips. What can i do? Can i also get new screws later to put in?
Hi,
If the T5 slips you may have not the correct size ? I have done may speaker, no screw was ever that tight. All 3 screws the same problem ?
Lift the corner of the left speaker up and slide it out around the battery to remove it from the upper case.
If I have a case assembly with battery and trackpad, the above instructions say to skip steps 18 - 44. So, how do the battery and trackpad disconnect otherwise since I need everything else to reassemble. Am I missing something?
after step 9 what??? i cannot see the next steps….
71 other people completed this guide.
15 Comments
Pretty much, there's another cable to disconnect, but we have a whole guide for the right speaker, too! Best of luck!
Hi! Are the L/R speakers compatible with the 13" Early 2015 models?
Great guide. I was able to dismantle the speaker and fixed the blown left speaker. Fit it back and it worked. Now, i’ll do that for the right speaker.
Went just as expected, thanks for the pro guidance!
Great guide! Feels like an easier replacement than “moderate”. My only note is to remind folks to remove the plastic tab protecting the adhesive on the underside, next to the connector. Seems like a no-brainer, but it may not be for everyone!
Is there a reason why you have to disconnect the battery during repair? Is it just to avoid accidental discharges and logic board problems?
Hi! Would this be the same process for the mid 2014 MacBook pro 13” Retina model? Thank you!
twas a breeze following this page! Thanks!
it was easy!!
Be sure to check your pan Left and Right after the repair to test. Go to System Preferences / Sound / Output … Balance.
There’s an other place to check for sound output volume. In the top menu Go / Utilities / Audio MIDI Setup … in Built-in Output. Be sure that the Channel Volume is equal.
Now, listen to the music!
For all the screws you use the P5 pentalobe screwdriver?
Carlos - Reply
Pentalobe is only for the screws on the bottom cover. The Torx screw driver is for the remainder.
Fredrik -
Is the Pentalobe screwdriver mentioned in the tools list? I did not have one so I used a filed down flat blade screwdriver. Not a fantastic idea, but it works.
Alex Birkett - Reply
Yes, it's mentioned on the top of this page. P5 Pentalobe to be precise. I didn't have one either, so I bought one from iFixit and that works fantastic. An absolutely precise fit, which is important especially when you might open your MacBook a couple of times during the years you own it. Not using the correct tool might do more harm to the screws than you want! I once had this with a Lenovo Yoga 3 Pro, which has Torx screws (T4 I think) and I used cheap Chinese quality tools, with the result that both the tool and one of the screws are damaged.
addvariety -
I never, ever, ever considered using anything but the correct tool on the Pentalobe screws. Too easy to strip and void your warranty (if still in effect), as well as make it almost impossible to get inside later for another upgrade or repair. The Wiha P5 Pentalobe screwdriver fits like a glove and costs only about $11 (a fraction of your drive's price)at Amazon.com. Get it!
marketing - Reply
is P5 supposed to be for all 10 screws? it works on the 2x 2.3mm at the top, but not for the 8x others for me. what size screwdriver for the 3mm? thanks
monsieurescargot - Reply
Yes, the p5 works for all 10 pentalobe screw heads for bottom cover. The the different size mm reference only refers to the difference in length of the screws, but again both heads are p5.
Antoine Thornton - Reply
I followed this exactly and was able to replace my broken trackpad. I did not have to replace the ribbon OR the battery. However I would suggest getting the ribbon since it’s fairly cheap, as for the batteries I was able to do it with a card only. I didn’t use any heat or the liquid but it takes some time. You really have to work the card in there to release the glue. Also you must be very careful not to bend the batteries or damage them, if you do you must replace with new. This took me about 1.5hrs and my computer works like new. Apple cost for this job was around $450, I did it for $120. Big ups to ifixit for this awesome tutorial, tool set and parts!
On a side note, only use quality tools, the cheap ones will break or strip the screws.
Dustin Steward - Reply
Note that the eight 3mm screws have a shoulder under the head, while the two 2.3mm screws are “full thread”, i.e., there is no shoulder under their heads. It’s important to put the two screws with no shoulder at the hinge of the cover.
All ten screws require a P5 Pentalobe screwdriver, preferably with a magnetized tip to help hold and position the screw.
All of the screws have blue “Loctite” thread locker compound on their threads. This is to help prevent the screws from working loose and falling out. Don’t attempt to clean the Loctite from the screws — leave it in place, and it will continue to help prevent the re-inserted screws from working loose.
When replacing the bottom cover, it is a good technique to insert and BEGIN tightening all ten screws BEFORE fully tightening any one screw. After all the screws have been started, then go around and finish tightening all of them. By doing this, you make it easier to feel that each screw has been started properly, and is not “cross-threaded”.
doubleclutch - Reply
This is what I found on my MBP mid-2014 13” Retina. All 10 used the same screwdriver. I didn’t see the blue “loctite” but I also got my computer refurbished.
Evan Shulman -
A good technique for starting to thread the screws when replacing them is to position and align the screw, and with the driver, gently turn the screw in the REMOVAL direction until you feel and hear a slight click. This click happens when the leading thread of the screw drops off of the leading edge of the thread in the hole — this is the point at which the threads are properly positioned for engagement. You can now turn the driver and screw in the TIGHTENING direction. This technique will help prevent accidental “cross-threading” of the screw, which will damage the threads permanently.
Note that this is a useful technique when installing ANY threaded fastener.
Just finished replacing my battery (MacBook Pro 13” early 2015), glad I did, the old ones were noticeably swollen. I was surprised to find the battery at 57% upon completion and charging the new battery. No problems with replacement however, kit arrived without the Pentalobe driver. I got a nice complete kit from Amazon for 20 euro in 2 days. iFixit offered a coupon on any future purchase but right now, I have no plans on needing anything. Nice gesture but would have preferred the driver in the kit in the first place.
Suggest having a small can of compressed air on hand to clean out the interior, after 4 years, mine was quite dirty. Ear buds and alcohol were the best I could do. And a magnetized driver is mandatory I think.
D M - Reply
REQUIRED PARTS (SCREWS) TO DO THIS JOB UNAVAILABLE HERE:
If your keyboard is riveted to the chassis as mine is, Late 2013 MBP 13” retina, you need about 100 screws to reattach the new keyboard.
ifixit does not have them. I did just now find them at Beetstech for $4.50 along with a back light $13 for the keyboard in case you want one. It looks like Beetstech is a big competitor of ifixit with an excellent reputation (like ifixit has) too. I just ordered these parts and will not happily be moving forward with my keyboard replacement.
Timothy Hardman - Reply
Fun Fact: I got three of the 2,3 mm Pentalopes … ;-)
Paco Demant - Reply
My PB had eight (8), 2.3 mm screws and two (2), 3.0 mm screws.
ellamama - Reply
Hi peeps,
I have a wifi problem on this MBP 13” early 2015 and was pleasently surprised to find your guide to changing the airport card.
However upon closer inspection it seems that on my MBP (purchased new or so I thought) the 3 antennae seem so have been soldered together at the point where they are clamped to the chassis. I have photos but cannot post here. Can anyone conform that where the 3 antennae wires are held to the chssis by the 2 scew metal support (just before disappearing into the screen hinge), the support is not meant to short the 3 wires together. This makes no sense for 3 seperate antennae wires.
Any advice /close up photos is welcome here.
dom
colonel mustard - Reply
Tip: Use post-it notes to keep track of screws
1. Pack of post it notes
2. Stick screws to the sticky part of the post it note
3. Write on the post it note which step and what kind of screw it is
ibash - Reply
Hi, in order to drain the battery I am running:
yes > /dev/null
in 4 terminals, so the CPU maxes out at almost 99%.
I hope this speeds up the battery draining process.
And the backlight is at maximum brightness :-)
You can see the cpu load in Activity Monitor.
Its draining at 20% per 15 minutes.
Any concerns about draining the battery in this way?
Andre van der Ham - Reply
Something I’ve been curious about, is it possible to upgrade a late 2013 Retina model MacBook Pro, with the improved 16gb ram and i7 processor logic board from the 2015 retina model? I’d be interested to try but not ready to shell out the $500+ to be the first lol
Chat Dawgie - Reply
The batteries of my MBP 13” (early 2015) were distended. due to outgassing. They are 3,5 years old but only had 340 cycles. I suppose that the batteries age faster when your computer is permanently plugged in.
When unscrewing the bottom lid, I didn’t have to exert any force to remove the lid as it already popped loose due to the expanded batteries.
Olivier Biot - Reply
By the way, on my pentalobe bit it reads 1.2 instead of P5.
