MacBook Pro 13" Retina Display Late 2013 Battery Connector Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. MacBook Pro 13" Retina Display Late 2013 Battery Connector Replacement, Battery Connector: step 1, image 1 of 1
    • If necessary, remove the plastic cover adhered to the battery contact board.
  2. MacBook Pro 13" Retina Display Late 2013 Battery Connector Replacement: step 2, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Battery Connector Replacement: step 2, image 2 of 2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  3. MacBook Pro 13" Retina Display Late 2013 Battery Connector Replacement: step 3, image 1 of 1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
Sam Goldheart
466,211 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 802
