Introduction
Rüste deinen RAM auf, damit dein MacBook schneller wird.
Entferne die folgenden zehn Schrauben, mit denen das untere Gehäuse am oberen Gehäuse befestigt ist:
Sieben 3 mm Kreuzschlitzschrauben
Drei 13,5 mm Kreuzschlitzschrauben
Löse die Rasten auf beiden Seiten des Riegels, indem du sie gleichzeitig weg vom RAM drückst.
Nachdem der RAM-Riegel herausgesprungen ist, kannst du ihn gerade aus seinem Sockel herausziehen.
Um dein Gerät wieder zusammenbauen, folge den Schritten in umgekehrter Reihenfolge.
160 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
5 Guide Comments
I bought and installed 4GB x2 RAM for my Mid 2009 15 inch MacBook Pro and it was easy and is working great. Before this I had 4GB and it was being maxed out. It was very easy. I did purchase the required tools which made it simple. I also swapped the battery at the same time. I am writing this from the same computer and it is working well. Good luck!
I had no trouble installing the 4 GB RAM I bought for my Mid 2009 15 Inch MacBook Pro. The mistake I made though was not realising that my machine has two RAM slots. I only bought one chip! So now I have to buy another one.
If you read this before you buy some RAM, make sure you check how many slots your computer has!
Also, I must say the customer support from ifixit is great. I messaged them about this and some other issues I was having and I got a detailed response from them within a couple of days. Thanks guys!
I replaced my original 2x 2gb ram with 2x 4gb RAM following your instructions. However, upon boot up, it’s only showing 1 of the 2 4gb chips. Any tips on how to get both seated correctly?
Never mind. I was able to pop the second chip back out and get it seated properly.
