Shop the Holiday Gift Guide
Introduction
Go to step 1 ↓
This guide details chip ID information for Apple's MacBook Neo. You can find the full teardown video and analysis here.
Special thanks to our community member Chunglin Chin for contributing to this!
This teardown is not a repair guide. To repair your MacBook Neo, use our service manual.
    1. MacBook Neo Chip ID, Main Board - Front Side: step 1, image 1 of 2 MacBook Neo Chip ID, Main Board - Front Side: step 1, image 2 of 2
      • Apple APL1V07 / 339S01851 A18 Pro applications processor layered under a SK hynix H58G66CK8HX139 8 GB LPDDR5X SDRAM memory
      • Apple APL109A / 343S00866 power management
      • SanDisk SDMVGKLK8-512G 512 GB NAND flash memory
      • Likely Apple 338S01330-B0 battery charger
      • NXP Semiconductors SE310S secure element
      • Texas Instruments SN2012027 USB Type-C port controller
      • Winbond W25Q80DV 1 MB serial NOR flash memory
      Ask FixBot
    2. MacBook Neo Chip ID: step 2, image 1 of 1
      • VIA Labs VL122-Q2 4-port USB 2.0 hub
      • Apple APL109O / 343S00861 power management
      • Cirrus Logic CS42L83A audio codec
      • Analog Devices MAX98360B 3.2 W audio amplifier
      • Texas Instruments TPS630250 adjustable buck-boost converter
      • Texas Instruments TPS61022 8 A boost converter
      • Possibly Texas Instruments LM3638 LED backlight driver
      Ask FixBot
    3. MacBook Neo Chip ID: step 3, image 1 of 1
      • Likely GigaDevice serial NOR flash memory
      • Likely STMicroelectronics serial EEPROM memory
      • Likely Texas Instruments eUSB2-USB 2.0 dual repeater
      • DC-DC converter
      • Texas Instruments INA190A3 current sense amplifier
      • current sense amplifier
      • Texas Instruments TPS259482A 8 A eFuse
      Ask FixBot
    4. MacBook Neo Chip ID: step 4, image 1 of 1
      • Texas Instruments TLV4041R1 single comparator w/ reference
      • Likely Renesas SLG46108 programmable mixed signal matrix
      • Likely Renesas mixed signal array
      • Likely Renesas SLG4xxxx mixed signal array
      • Texas Instruments TPS7A2018P 300 mA / 1.8 V LDO regulator
      • Nexperia 74AVC4T245GU 4-bit dual-supply translating transceiver
      • Texas Instruments SN74AVC4T774 4-bit dual-supply bus transceiver
      Ask FixBot
    5. MacBook Neo Chip ID: step 5, image 1 of 1
      • Texas Instruments LSF0101 single bidirectional multi-voltage level translator
      • Nexperia 74AXP1T45GX 1-bit dual-supply translating transceiver
      • Texas Instruments SN74AUP1G17 single Schmitt-trigger buffer
      • Texas Instruments SN74AUP1G08 single AND gate
      • Nexperia 74AUP1G08GM single AND gate
      • Texas Instruments SN74AUP1G34 single buffer
      Ask FixBot
    6. MacBook Neo Chip ID: step 6, image 1 of 1
      • MediaTek MT7932EEA Wi-Fi 6E & Bluetooth 6 controller
      • Likely Sony CXA4626GC RF switch
      Ask FixBot
    7. MacBook Neo Chip ID, Main Board - Back Side: step 7, image 1 of 2 MacBook Neo Chip ID, Main Board - Back Side: step 7, image 2 of 2
      Ask FixBot
    8. MacBook Neo Chip ID, Touchpad: step 8, image 1 of 2 MacBook Neo Chip ID, Touchpad: step 8, image 2 of 2
      • Broadcom BCM5976TC1KFB3G touchpad controller
      • onsemi CAT24S128C4ATR 16 kB serial EEPROM memory
      Ask FixBot
0 Guide Comments
Past 24 Hours: 19
Past 7 Days: 170
Past 30 Days: 750
All Time: 6,160
