MacBook Neo Battery Disconnect
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. MacBook Neo Battery Disconnect, Remove the battery connector cover: step 1, image 1 of 1
      • Use a Torx Plus 3IP driver to remove the two 1.7 mm‑long screws securing the battery connector cover.
      • While the MacBook Neo uses Torx Plus screws, standard Torx bits also work (T3 in place of 3IP, for example). Apply constant, downward force to prevent stripping the screw.
      Ask FixBot
    2. MacBook Neo Battery Disconnect: step 2, image 1 of 2 MacBook Neo Battery Disconnect: step 2, image 2 of 2
      • Use tweezers or your fingers to remove the battery connector cover.
      Ask FixBot
    3. MacBook Neo Battery Disconnect, Disconnect the battery: step 3, image 1 of 2 MacBook Neo Battery Disconnect, Disconnect the battery: step 3, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the battery press connector.
      • To reconnect, align the connector carefully over its socket and press down—first on one of the short sides, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Ask FixBot
Finish Line
Nick Schultz
65,697 Reputation
343 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 15
All Time: 163
