Installing MacBook Core Duo LCD Assembly
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Installing MacBook Core Duo LCD Assembly, LCD Assembly: step 1, image 1 of 2 Installing MacBook Core Duo LCD Assembly, LCD Assembly: step 1, image 2 of 2
    • Remove the small piece of foam tape stuck down above each of the bezel covers.
  2. Installing MacBook Core Duo LCD Assembly: step 2, image 1 of 2 Installing MacBook Core Duo LCD Assembly: step 2, image 2 of 2
    • Use a spudger to slide the left bezel cover towards the LCD panel.
    • Do not lift up vertically on the cover! Unlike the large display bezel, this one has horizontal hooks to keep it in place. These will break easily.
    • Lift the left bezel cover off the display assembly.
  3. Installing MacBook Core Duo LCD Assembly: step 3, image 1 of 2 Installing MacBook Core Duo LCD Assembly: step 3, image 2 of 2
    • Use a spudger to slide the right bezel cover toward the LCD panel.
    • Lift the right bezel cover off the display assembly.
  4. Installing MacBook Core Duo LCD Assembly: step 4, image 1 of 2 Installing MacBook Core Duo LCD Assembly: step 4, image 2 of 2
    • Lift the inverter out of the display slightly and disconnect the backlight cable from its right side.
    • Place the inverter back down in its recess.
  5. Installing MacBook Core Duo LCD Assembly: step 5, image 1 of 1
    • Remove the single 3.2 mm Phillips screw securing the display data cable to the right clutch hinge.
  6. Installing MacBook Core Duo LCD Assembly: step 6, image 1 of 1
    • Move the display data cable out from under the mounting arm of the right clutch hinge.
  7. Installing MacBook Core Duo LCD Assembly: step 7, image 1 of 1
    • Remove the twelve 4.2 mm Phillips screws securing the LCD assembly to the rear display bezel.
  8. Installing MacBook Core Duo LCD Assembly: step 8, image 1 of 1
    • Lift the LCD assembly out of the rear display bezel, minding any cables that may get caught.
  9. Installing MacBook Core Duo LCD Assembly: step 9, image 1 of 1
    • Be sure to keep track of the small magnet along the left side of the display. It may be stuck to the LCD frames or to the rear display bezel. When installing it, be sure short side is facing upward.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 458
