Installing MacBook Core Duo LCD Assembly
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Installing MacBook Core Duo LCD Assembly, LCD Assembly: step 1, image 1 of 2 Installing MacBook Core Duo LCD Assembly, LCD Assembly: step 1, image 2 of 2
    • Remove the small piece of foam tape stuck down above each of the bezel covers.
  2. Installing MacBook Core Duo LCD Assembly: step 2, image 1 of 2 Installing MacBook Core Duo LCD Assembly: step 2, image 2 of 2
    • Use a spudger to slide the left bezel cover towards the LCD panel.
    • Do not lift up vertically on the cover! Unlike the large display bezel, this one has horizontal hooks to keep it in place. These will break easily.
    • Lift the left bezel cover off the display assembly.
  3. Installing MacBook Core Duo LCD Assembly: step 3, image 1 of 2 Installing MacBook Core Duo LCD Assembly: step 3, image 2 of 2
    • Use a spudger to slide the right bezel cover toward the LCD panel.
    • Lift the right bezel cover off the display assembly.
  4. Installing MacBook Core Duo LCD Assembly: step 4, image 1 of 2 Installing MacBook Core Duo LCD Assembly: step 4, image 2 of 2
    • Lift the inverter out of the display slightly and disconnect the backlight cable from its right side.
    • Place the inverter back down in its recess.
  5. Installing MacBook Core Duo LCD Assembly: step 5, image 1 of 1
    • Remove the single 3.2 mm Phillips screw securing the display data cable to the right clutch hinge.
  6. Installing MacBook Core Duo LCD Assembly: step 6, image 1 of 1
    • Move the display data cable out from under the mounting arm of the right clutch hinge.
  7. Installing MacBook Core Duo LCD Assembly: step 7, image 1 of 1
    • Remove the twelve 4.2 mm Phillips screws securing the LCD assembly to the rear display bezel.
  8. Installing MacBook Core Duo LCD Assembly: step 8, image 1 of 1
    • Lift the LCD assembly out of the rear display bezel, minding any cables that may get caught.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 458
