MacBook Air 13" Early 2014 Left Speaker Replacement
  1. MacBook Air 13" Early 2014 Left Speaker Replacement, Lower Case: step 1, image 1 of 1
    Tool used on this step:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Buy
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. MacBook Air 13" Early 2014 Left Speaker Replacement: step 2, image 1 of 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Early 2014 Left Speaker Replacement, Battery: step 3, image 1 of 1
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Do not lift upward on the connector as you disconnect it.
  4. MacBook Air 13" Early 2014 Left Speaker Replacement: step 4, image 1 of 1
    • Remove the following five screws securing the battery to the upper case:
    • Three 6.3 mm T5 Torx screws
    • Two 2.4 mm T5 Torx screws
  5. MacBook Air 13" Early 2014 Left Speaker Replacement: step 5, image 1 of 1
    • When handling the battery, avoid squeezing or touching the four exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  6. MacBook Air 13" Early 2014 Left Speaker Replacement, Left Speaker: step 6, image 1 of 1
    • Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
    • Pry up from beneath the wires.
  7. MacBook Air 13" Early 2014 Left Speaker Replacement: step 7, image 1 of 3 MacBook Air 13" Early 2014 Left Speaker Replacement: step 7, image 2 of 3 MacBook Air 13" Early 2014 Left Speaker Replacement: step 7, image 3 of 3
    • Use the flat end of a spudger to pry the left speaker off the adhesive securing it to the upper case.
    • Remove the left speaker from the upper case.
Jeff Suovanen
429,028 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,432 Guides authored
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 28
All Time: 4,480
